  Clutch pedal squeak
Clutch pedal squeak by Scott574
Started on: 11-17-2015 07:43 PM
Replies: 5 (677 views)
Last post by: erniehawk on 11-18-2015 08:01 AM
Scott574
Report this Post11-17-2015 07:43 PM Click Here to See the Profile for Scott574Send a Private Message to Scott574Edit/Delete MessageReply w/QuoteDirect Link to This Post
85 GT 4 spd manual
I'm trying to chase down an annoying squeak in my clutch pedal area. I was originally thinking it was a pedal bushing, but it only makes the noise when the clutch is engaged, not disengaged. It actually sounds more like a loud chirp than a squeak. What should I be checking to isolate the problem?
[This message has been edited by Scott574 (edited 11-17-2015).]
Total ratings: 465
Report this Post11-17-2015 07:51 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think it's necessarily unusual that the squeak would be worse when you're stepping on the clutch pedal as opposed to releasing it. On one of my Fieros, I had to take the clutch pedal assembly apart to lubricate the nylon bushings because of a squeak. PIA, but the situation was resolved. It's possible you could spray something in there that would help without disassembling everything.
Scott574
Report this Post11-17-2015 08:00 PM Click Here to See the Profile for Scott574Send a Private Message to Scott574Edit/Delete MessageReply w/QuoteDirect Link to This Post
It only chirps when I release the pedal, nothing when I step on it.
Total ratings: 465
Report this Post11-17-2015 08:05 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, in that case it's low muffler juice.
Rodney
Total ratings: 267
Report this Post11-18-2015 05:29 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The banjo to the clutch pedal is steel on steel on the early Fiero's. Later Fiero's had a smaller pin on the clutch pedal and a black plastic bushing in the banjo. That is probably where the squeak is coming from. Take the banjo off the clutch pedal and put some grease on them.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
erniehawk
Report this Post11-18-2015 08:01 AM Click Here to See the Profile for erniehawkSend a Private Message to erniehawkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Scott check the pedal and see if the steel "U" part is bent ,I've never seen a Fiero that did not have some amount of bend on that part of the clutch pedal. The misalignment will also make the pin bushing squeak.
Denise, Bristol PA (Ernie is my Brother) 86 SE, stock resto. Jasper reman, 5spd Isuzu
