  Plastic around wiper blades
Plastic around wiper blades by painandgain99
Started on: 11-16-2015 10:10 PM
Replies: 12 (777 views)
Last post by: jim94 on 11-28-2015 01:23 PM
painandgain99
Report this Post11-16-2015 10:10 PM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry im not sure the actual name of this piece so i couldnt look up how to remove it, i was wondering if it was easy and how to remove the plastic guardat the bottom of the windshield right under the wiper blades ? Id like to plasti dip mine as its all faded out looking.
87' GT 5 speed 😤 16 years old
My IG for daily motivation: Alpha_Photos
85gtnstar
Report this Post11-16-2015 11:13 PM Click Here to See the Profile for 85gtnstarSend a Private Message to 85gtnstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is 4 screws i believe right below the windshield an 2 right by the fenders. And then i believe 4 push in christmas tree things by the vents. And of coarse remove the windshield wiper arms. All you have to do is pop the hood and raise it to access it
painandgain99
Report this Post11-16-2015 11:37 PM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
Theres a tube i believe for wiper fluid, i dont know how to get this off or how to get the wiper blades off. I dont want to break anything aha
seajai
Total ratings: 51
Report this Post11-17-2015 02:19 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
The part you are talking about is called the cowl panel. It is held on with screws that go horizontally under the windshield as well as a couple of clips along the front edge and a plastic rivet that goes through the pop-up spring in the middle. To remove the wiper arms, lift up on the arm and insert a small drill bit into the hole on the side at the base where the arm attaches to the pivot. This will hold the arm up against the spring tension and allow you to rock it off of the pivot. The hose for the washer fluid should just unplug from the tee.
https://www.fiero.nl/forum/A...130314-2-114917.html
Don't use Plasti-Dip, it wont hold up. I used a wipe-on black trim restorer on mine that worked pretty well.
[This message has been edited by seajai (edited 11-17-2015).]
85gtnstar
Report this Post11-17-2015 07:28 AM Click Here to See the Profile for 85gtnstarSend a Private Message to 85gtnstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
You will have to wiggle the wiper arms to get them loose if they are like mine were. Years of dirt and grime corroding them on there.
Report this Post11-17-2015 09:43 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Save the Christmas Tree grommets and take them to your parts store for comparison. You may have to buy an assortment of push-ins to get the size and quantity you need for replacing them. The two on the ends are the smallest if I remember and may be the most difficult to find.
I used Dupli-Color Flexible Bumper Spray as an initial coating on mine. Then I over-sprayed that with Rustoleum High Temp Engine Enamel. It's still looking very good after more than a year. The high temp paint doesn't bond extremely well to the plastic, but the bumper spray acts as a primer and bonds very well.
When replacing the screws, be sure to clean the rust from them very well. Purchase a tube of Ultra RTV sealant and put a liberal amount of it on the screw hole on the body. Let it cure for about 10 minutes then replace the cowl cover. These screw holes are sealed from the factory to prevent water seepage into the passenger compartment. I have some left over butyl windshield setting tape and I just tear off a small chunk to stick on each hole.
To be sure I get the wipers back in the same place, I use a Sharpee marker and mark along the blade to show the position against the windshield. Then I remove the arms.
[This message has been edited by fierofool (edited 11-17-2015).]
Tony Kania
Total ratings: 305
Report this Post11-17-2015 10:09 AM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I highly recommend Meguires Back to Black. It works. And lasts.
hnthomps
Total ratings: 50
Report this Post11-18-2015 10:28 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I painted mine in place using Krylon semi gloss for plastic paint. It has been a couple of years and everything still looks good.
Nelson
rogergarrison
Total ratings: 551
Report this Post11-19-2015 06:00 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use Back to Black on parts like that myself.
jaskispyder
Total ratings: 205
Report this Post11-20-2015 08:08 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used to use liquid shoe polish, but then I just painted the cowl, black
As for Back to Black, I have used it on the Aztek (lower trim on earlier models was unpainted plastic), but it lasts about a week, if that. I need to try something before the thing starts rusting too much and I stop caring
Report this Post11-20-2015 05:59 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Note: 87-88 have same "rivets" but some as part of cowl cover.
See my Cave, Windshield Wipe
rogergarrison
Total ratings: 551
Report this Post11-22-2015 03:40 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use black liquid scuff coat shoe polish myself, but more for soft parts like dash pads and steering wheels. It does work great on those. Never tried it on hard parts.
jim94
Report this Post11-28-2015 01:23 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have found that most products when wet tend to water spot. I found rain-x with window cleaner works great and doesn't water spot. Is it good for plastic I don't know. I do like pledge .
