  88gt alternator bolt frozen.
88gt alternator bolt frozen. by winger1955
Started on: 11-06-2015 11:44 PM
Replies: 11 (792 views)
Last post by: 84fiero123 on 08-28-2016 08:30 PM
winger1955
Report this Post11-06-2015 11:44 PM Click Here to See the Profile for winger1955Send a Private Message to winger1955Edit/Delete MessageReply w/QuoteDirect Link to This Post
alternator went bad . trying to remove it. can't seam to get the top bolt to break loose. have been spraying with pb blaster for 5 days know. bolt head is starting to round off on me. any help before I totally screw it up. have a new alternator ready to go in.
viperine
Report this Post11-06-2015 11:56 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had to remove this same, very stuck, bolt from a broken alternator bracket. Fortunately, I had the added benefit of removing the bracket from the engine with the alternator still attached to it, and it took a good impact wrench to free this bolt up. Not sure how easily an impact wrench would reach in there, and I might suggest a specialty socket for rounded heads from this point on. The last inch or two of this bolt is all that's threaded, so heat may help if used carefully. Good luck.
LorenBateman
Report this Post11-07-2015 12:13 AM Click Here to See the Profile for LorenBatemanSend a Private Message to LorenBatemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you get a chisel on the head of the bolt and smack it on the left side
Report this Post11-07-2015 01:15 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Long pivot bolt?
Carefully Heat the alt where bolt go thru. Aluminum will expend and might help.
css9450
Total ratings: 87
Report this Post11-07-2015 05:11 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have broken a few of these over the years. Anymore, I find it advantageous to get known good ones (and brackets) when I can find them in the junkyard and save them.
Some have had good luck by first tightening the bolt a tiny bit before trying to loosen it.
creaky78
Report this Post11-07-2015 06:02 AM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
This works in many cases. Also, try using a drift and hammer to sharply strike the bolt head, might help.
85 SE VIN 9
Report this Post11-07-2015 02:46 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Time seems to help the PB blaster work, perhaps simply by allowing the bolt head to dry.
deloreanant
Report this Post08-28-2016 02:50 PM Click Here to See the Profile for deloreanantSend a Private Message to deloreanantEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm having the exact same problem. PB for days, hitting the head, tried tightening and then trying to loosen, even with a breaker bar it didn't budge, impact wrench, and torch, but none of these things have worked for me so far. Winger, did you finally get it? What worked for you? I'm replacing this bolt with a stainless one if I ever get it out.
84fiero123
Total ratings: 325
Report this Post08-28-2016 03:05 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
You are tapping the bolt with a small hammer every time you spray it right, it says to do that on the instruction if I am not mistaken, if that doesn't work do as ogre sad and use a little heat, little I said little, don't use anything more than a standard propane torch. work the bolt in both directions each time you try to move it, if it does move in the other direction, just a little, spray it again and tap the bolt, then try to turn it the other way, use a 6 point socket, less chance of rounding off the bolt head.
Steve
deloreanant
Report this Post08-28-2016 07:10 PM Click Here to See the Profile for deloreanantSend a Private Message to deloreanantEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the quick reply. I read it and got to work. I honestly don't think I was applying PB and then tapping with a hammer. I think would spray it on, let is soak, and then smack it with a 3lb hammer before going at it with my impact wrench. I ended up applying plenty of heat to the bracket around where the bolt is threaded. Not enough to make it red, but way hotter than anything you'd want to accidentally touch. It was enough to make it smoke. Then with some advice from Bozzie, I took the deck lid off to get more range of motion with breaker bar. Finally got that thing free. Didn't even break the bolt. Took a long to time work it out. Had to do some back and forth stuff in the beginning and then back it out with the breaker bar most of the way. Thanks guys! Will be replacing with stainless so this doesn't happen again..... hopefully.
lateFormula
Report this Post08-28-2016 08:25 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am a fan of replacing steel screws and bolts with stainless versions, but be advised: the alt bracket is aluminum and if you are going to use a stainless bolt you should coat the threads with anti-seize. Completely coat the threads with anti-seize. If you don't fully coat the threads the bolt can cold weld into the aluminum due to galvanic corrosion.
[This message has been edited by lateFormula (edited 08-28-2016).]
84fiero123
Total ratings: 325
Report this Post08-28-2016 08:30 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
At that point you are almost cutting new threads, get a new bolt of the right size and thread, you obviously don't want to use the old one and to be honest I bet the new one may not fit the old threads any more after all that heat. you might want to pick up a tap for the threads and run it threw those threads before ever even trying to put that new bolt threw.
aluminum is soft compared to steel and can get damaged real easy by a lot of heat. so if the new, right thread bolt even gets hard to turn run the tap threw the thread. Then again there is always helicoils or you could do like my Dad did on one of his old cars, just drill the hole our and put a nut and bolt on. Hey it worked !
Good work there dude.
Ayup coat the crap out of any part of the bolt that even touches the aluminum with never seize, this is what happens to those steel lug nuts on aluminum rims with steel nuts, you must be familiar with those.
Steve
[This message has been edited by 84fiero123 (edited 08-28-2016).]
