  GT Sail Panel Window Removal
GT Sail Panel Window Removal by Thunderstruck GT
Started on: 10-31-2015 10:37 AM
Replies: 10 (1122 views)
Last post by: jaskispyder on 11-02-2015 03:48 PM
Thunderstruck GT
Total ratings: 99
Report this Post10-31-2015 10:37 AM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thread has been closed by OP
[This message has been edited by Thunderstruck GT (edited 04-19-2016).]
dobey
Total ratings: 371
Report this Post10-31-2015 02:43 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fishing line and heat, just like removing the molding and badges on newer cars.
It's still a bit difficult though, since you've got to deal with the curve at the front, drip rails, etc…
Thunderstruck GT
Total ratings: 99
Report this Post10-31-2015 03:34 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMSA GT
Total ratings: 253
Report this Post10-31-2015 03:38 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Thunderstruck GT:
Never thought of fishing line. Wouldn't that stretch and break with the heat?
Would the heat damage the window or can they take a fair amount?
I'm assuming you use a heavy curved sewing needle to poke the line through?
Thanks
The factory already included the "fishing line" behind the panel. The problem is that it is so old that even if you find the line, it will break as soon as you pull on it.
Total ratings: 466
Report this Post10-31-2015 04:33 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The drip rails are very easy to remove, so that at least is a non-issue.
Every time I try to remove them they either come off in pieces or the black background gets scratched.
I found an '88 GT in a local wrecking yard a year ago. One sail panel was already sort of "crazed", the other was in good shape. I tried to remove the bad one first, basically using a butter knife with a very slight serrated edge (which I happened to have in my tool box). I got most of the panel loose before I got to the cracked part... and then the panel exploded. So much for that one.
I then spent at least half an hour removing the good panel. I successfully got it off the car, but I rubbed a bit of the black off in one corner about the size of a dime. I'm wondering if the black coloration can be restored in that small area prior to the panel being reinstalled on another GT?
[This message has been edited by Patrick (edited 10-31-2015).]
dobey
Total ratings: 371
Report this Post10-31-2015 04:41 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
You apply heat to the area where the adhesive is to soften it up, but not so much to damage the plastic. Then you use fishing line of a decent rating to "saw" through the adhesive, while a helper gently pulls the panel away from the body.
You don't heat the fishing line up. Use a hair dryer to heat the panel areas where the adhesive is, but keep moving it around and don't keep it pointed at a single location too long, or yes, it can damage things. Of course too much heat can damage it, but how much heat do you think it's exposed to sitting in direct sunlight all day at a car show?
Total ratings: 328
Report this Post10-31-2015 07:35 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone that can remove a 30 yr old brittle quarter window without cracking it, is a better mechanic than I am. To reiterate, the problem is that these plastic windows are old, have faced extremes of temperature and as a result are brittle and easily cracked. I guess that there is a way to get the windows out with fish line, but even if you do, you might scratch the paint and then how long can you expect them to last? You might even crack them by pushing to set and reinstall them.
IMO. the best alternative is to push out the old windows (they will come out in pieces so wear leather gloves ) saturate the old mounting tape with 3M Adhesive Remover (its safe), scrape off the old tape and get a perfectly clean frame on which to work. Then buy a set of Chris Cooks quarter windows and install them. The graphics are perfect, the fit is usually good, the curvature is slightly different than the originals but hardly noticeable. To get them perfectly centered, I apply the tape that comes with the window as it was on the old ones , then I spray Windex on the perfectly cleaned frame, manipulate the window in position and press them in place. The only problem is that this has to be done on a hot day (80* or higher) for the double sided tape to stick, cure and adhere properly. In cool/cold weather its next to impossible to get a good bond. A heat gun might work but get too close and the window melts. A shop heater directed on the window frame area might be the best bet.
If you try to remove the old windows and reinstall them, you will still need the 1/4" double sided foam tape to reattach them. Let us know how everything works out.
[This message has been edited by Dennis LaGrua (edited 10-31-2015).]
Thunderstruck GT
Total ratings: 99
Report this Post10-31-2015 09:00 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
sardonyx247
Total ratings: 219
Report this Post10-31-2015 11:25 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have taken off two in the last month. one was even cracked and stuck on there good, but I didn't have the crack grow or crack more.
What I use is a flexible bread knife, with a good serrated edge. and saw through the adhesive. And a super sharp paring knife for what you can reach with it.
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
Total ratings: 328
Report this Post11-02-2015 03:38 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have used and have noticed that the repop windows don't fit the openings like the originals.
The originals also have a certain shade of tint to them that isn't in the repops. The repops I have seen are either perfectly clear or smoke tint. The repops also are not convex like the originals.
The vendors of GT Quarter windows are very narrow and the product varies widely in quality. I have had good luck with Chris Cooks reproduction GT Quarter panels. When I compared the graphics on Chris windows to the original ones they were spot on. The fit is good but at times the sizing can be just a tiny off. If it is too far off, Chris has been known to take them back and exchange them for better fitting windows.
The key to a good fit is to center them on a perfectly clean window frame using Windex spray before placement This allows you shift them into a position that is equidistant from top and bottom.
As for the curvature, Chris windows have it, but it is not as pronounced as on the GM originals. At this point in time these are the only quarter windows that have a stock type appearance and Chris is the only vendor who has come close to a quality reproduction. You can find Chris Cooks windows on eBay.
jaskispyder
Total ratings: 205
Report this Post11-02-2015 03:48 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Get something called Spiderwire, or something similar to cut the adhesive. It is high-strength fishing line (not - standard line). Wear gloves. Use a needle or something to get it through.
