Even better, I have videos on the installation
Maybe you might find them useful. Make sure you check the text of my YouTube videos as I include links to the parts you need to complete the install. I loved the 3.4 and feel that any Fiero in need of an engine swap should get at least the 3.4 or better. I'll actually be pulling my 3.4 out in a few weeks to take my car to the next level. I'm attempting my first a 3800 install on a spare cradle...and yes I'm doing a video of that swap as we speak. I have other videos if your interested in the 7730 swap, removing bushings from an engine cradle or control arm, cold air intake or rear sway bar while your engine and cradle are outGood luck on your build!
If you need assistance on pulling your engine.
3.4 pushrod starter relocation conversion and Flexplate installation
How to convert a 3.4 push rod engine to Distributor based (HD)
How to Convert the Oil Pressure Sending Unit for a 3.4 conversion
How to install the oil level tube & Oil Filter Adapter for a 3.4 pushrod engine
How to convert the oil pan from a 2.8 engine to a 3.4 pushrod
How to convert the 3.4 timing chain cover & Harmonic balancer
Cutting a 3.4 block so that it will mate to an automatic transmission
Fiero fuel injector 15lbs to 17lbs conversion for 3.4 pushrod engine
Some extra videos just for kicks
First start and first run of the 3.4 push rod engine
0-60 RACE - 87 Pontiac Fiero GT w 3.4 engine VS. 88 MERA
87 Fiero GT 3.4 Pushrod with 7730 ECM & DIS
88 MERA #8013
85 Fiero SE with 3.1 pushrod
86 Fiero SE 2.8 stock
http://www.youtube.com/LostNotForgotton
