  Replacing sheared off cruise control stalk without removing steering wheel
Replacing sheared off cruise control stalk without removing steering wheel by da.slyboy
Started on: 10-23-2015 10:01 AM
Replies: 3 (514 views)
Last post by: Dennis LaGrua on 10-24-2015 09:40 AM
da.slyboy
Report this Post10-23-2015 10:01 AM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I had a little bit of wet weather this morning that was just enough to make is slicker than normal. Long story short, I had too much power going around a corner and the rear broke loose causing a little bit of corrective steering. Part of my reaction had me smacking the cruise control lever hard enough to break the at the point where the rod inserts into the column. I don't believe I broke the switch because I can still use the turn signals and if I hold the stalk in place I can operated the wipers/washer. My question is if anyone has broken the stalk at the same spot as me and was able to remove the broken piece without removing the steering wheel.
Already ordered another stalk, but have a busy couple of weeks ahead of me so trying to see if some time can be saved.
steve308
Total ratings: 58
Report this Post10-23-2015 11:02 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is there enough of the stalk left that you can get a pair of plyers or vice grips on it? If so, grab ahold of the "stub" and turn it towards you (sitting in the seat) it should come out. There is a bunch of good info online including a few how to do video's on how to replace the stalk. I just did mine --- took me a couple of beers and about 20 min.
MarkS
Report this Post10-23-2015 12:26 PM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
My favorite way to do anything!
Wish Pennocks was around when mine broke in the late eighties..
BR's,
Mark
86 SE V6 Auto
65 Tempest 400 CID
2008 G6 GT "Street" Coupe
2005 Buick 3.6 Rendezvous
2001 Olds Silhouette (AKA The Band Van)
Report this Post10-24-2015 09:40 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look down on the steering column where the stalk wire is plugged in. Pull out the connector. Attach a strong piece of string or a piece of light wire and wrap the connector with a light layer of electrical or duct tape. Pull the stalk out slowly and watch that you have the correct wire. The wire with the connector will come out and take the string/wire with it. Attach this to the new stalk wire and use it to pull it through the column and down to where it needs to be plugged in. This is the only way that I know of to replace the stalk without disassembling anything.
