  Perplexing new starter problem
Perplexing new starter problem by FieroCat
Started on: 10-08-2015 05:22 PM
Replies: 20 (634 views)
Last post by: FieroCat on 10-12-2015 11:27 AM
FieroCat
Report this Post10-08-2015 05:22 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been having some starting troubles, for some reason there is this intermittent issue of the starter spinning but not engaging the flywheel. I decided to change out the starter with a new (rebuilt) unit. Worked fine for about a week, then the issue came back. Spinning but no flywheel engagement. So I swapped it out with another new one under warranty, same problem right out of the box this time.
-Tried jumping the terminals directly with a screwdriver and no change.
-Tried removing the shim. Doing this caused a lot of grinding noise with starting and the engine did turn a bit. But no proper meshing, only awful grinding.
I inspected the flywheel teeth and there are no significant chips or missing teeth. Everything seems fine...
What could be happening? There must be excessive clearance, but how? Any help appreciated.
My Fiero: 1986 Pontiac Fiero GT, V6, 4-speed manual
Report this Post10-08-2015 05:24 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Id check the wiring to be sure enough voltage is getting to the starter.
FieroCat
Report this Post10-08-2015 05:31 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wiring seems to be good. It spins fast, could it be just not enough voltage to extend the pintle all the way?
Report this Post10-08-2015 05:36 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The starter is grounded through the engine block. If there is something in the way....dirt....grease..... the power transferred goes way down. Voltage is one thing, but you need Amps too.
FieroCat
Report this Post10-08-2015 05:41 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shim and mounting surfaces were clean. Should be well grounded. It looks to be more of an alignment issue.
Total ratings: 460
Report this Post10-08-2015 08:42 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd be looking at electrical resistance in both battery cables (assuming the battery itself is fine).
sardonyx247
Total ratings: 219
Report this Post10-09-2015 04:38 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
When you get a starter( some come with this) or a shim pack the 'round rod', that is supposed to be the correct distance between the starter and flywheel teeth.
Not the easiest to use, but the correct way. That is most of the time a shim issue, there are tons of different thickness shims, not just one.
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
FieroCat
Report this Post10-09-2015 06:49 AM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is odd is that it worked fine for a while with the factory shim. Now it doesn't contact. The shim is maybe a sixteenth of an inch thick. Removing it caused terrible grinding.
sardonyx247
Total ratings: 219
Report this Post10-09-2015 07:05 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Try thinner or add another. I understand the oddity of it worked before, but now you have to deal with the now.
Food for thought, things wear over time.
FieroCat
Report this Post10-09-2015 07:56 AM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
That may be the best course of action, though my shop instructor mentioned that it's possible that the flywheel and starter pinion gear are mismatched, or that the carquest starter from advance isn't really the correct one (even though it looks the same). Was there more than one type of flywheel for the Fiero trannys? Any variations in tooth count?
sardonyx247
Total ratings: 219
Report this Post10-09-2015 08:02 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes there is, the 88s have a neutral balanced flywheel, and 85-87 have an external balanced (talking about V6s here) same tooth count though (as far as I know, pretty sure though)
sardonyx247
Total ratings: 219
Report this Post10-09-2015 08:10 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
sardonyx247
Member since Jun 2003
Speaking of wiring/grounding issues make sure your ground strap did not break, (it happens) even try a jumper cable(a good one) between the battery ground and the engine block, you can also ohm the battery neg and the block, should be close to zero. But sounds like a shim issue to me, BTW starters are made different, thus the point of shims, in the "Help" section they have a shim kit (cheap) with all kinds of different sizes, (other wise they wouldn't be needed)
Grinds = too close
sounds like it spins freely = too far
adjust from there
FieroCat
Report this Post10-09-2015 09:54 AM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've tried various shims all morning, from .5mm to 2mm. None will mesh properly, they either spin or grind.
Report this Post10-09-2015 09:58 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
when they grind....do they stop rotating or continue grinding away?
fierosound
Total ratings: 287
Report this Post10-09-2015 10:16 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try using half a shim under the outboard bolt.
https://www1.remyinc.com/we...techtips/TBSTR01.pdf
[This message has been edited by fierosound (edited 10-09-2015).]
FieroCat
Report this Post10-09-2015 01:33 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found the problem after removing the flywheel dust cover and turning it over. Ring gear is separated from the flywheel.
Total ratings: 460
Report this Post10-09-2015 07:22 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Weird.
Is this an OEM flywheel, or some aftermarket one?
FieroCat
Report this Post10-11-2015 06:54 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
No idea, I have no records from the PO. Tranny's probably gonna have to come out. My shop instructor said welding the ring gear at about six evenly spaced points should solve it, but only if the gear isn't cracked. Will be inspecting it to see.
WHEELIE
Report this Post10-11-2015 09:03 PM Click Here to See the Profile for WHEELIEClick Here to visit WHEELIE's HomePageSend a Private Message to WHEELIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had the same thing happen on my 85 gt. Welded the ring gear to the flywheel and it worked fine.
Wheelie
Total ratings: 460
Report this Post10-11-2015 09:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't this be done with the tranny in the car... with the inspection cover removed?
FieroCat
Report this Post10-12-2015 11:27 AM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, it is easy to get to. Only would have to remove the tranny if welding can't be done.
