  Car Chemistry exhaust inserts
Car Chemistry exhaust inserts by solotwo
Started on: 10-07-2015 10:55 PM
Replies: 17 (432 views)
Last post by: solotwo on 10-10-2015 08:59 AM
solotwo
Total ratings: 62
Report this Post10-07-2015 10:55 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone used these?
I need to quite the car down before I go deaf. LOL
Total ratings: 460
Report this Post10-07-2015 11:16 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do a search? A few threads where they're mentioned HERE.
Report this Post10-08-2015 07:56 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The old Honda 250 and 305 Scrambler motorcycles of the 60's used a baffle that looked similar to that. They could be removed for off-road use. I don't know if the SpinTech devices work the same, but they appear very similar. The Honda baffles were very effective in reducing the noise. In the case of the Hondas, the baffle was in the end of the pipe, held in by a single bolt. For the V6 Fiero, you would need 4 or you'd need to cut your pipe and install it upstream of the muffler.
deezil
Report this Post10-08-2015 10:16 AM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. I used one in my f-body muffler on my 3800sc.
The car literally sounds just like the 2.8 and no rasp. Love it.
Lou and Blue
Report this Post10-08-2015 11:28 AM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would think these are causing increased exhaust restriction though which equals less horsepower.
I have the magnaflow setup on my 3800sc (with a magnaflow bullet cat) and it sounds awesome, no rasp.
Louis Duet --- Baldwin, Long Island, NY
"I spread my wings, I try to fly. I believed in myself when there was nothing right. I know I'm dust and oh, we are sand. But we give of ourselves, as best as we can."
-G. Rossdale
"Blue" <= '85 Fiero GT 3800sc series 2
"Boo" <= '81 Delorean DMC-12, VIN #5835, Stock PRV engine, Peugot 604 Intake manifold, Exhaust headers, Anti-3rd brake light
dobey
Total ratings: 371
Report this Post10-08-2015 11:33 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Quiet exhaust means enough restrictions, or enough length, to make it quiet. Losing 3 HP at peak in a street car is not going to matter.
deezil
Report this Post10-08-2015 02:04 PM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ran this 3800 with a magnaflow for a bit. All 2.5 piping. It sounded like garbage.
I switched to the f body hooker muffler I originally had made with the insert. There was no discernable difference other than the car no longer sounds horrible.
Lou and Blue
Report this Post10-08-2015 02:42 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe mine sounds aweaome because it's the long magnaflow that 'just fits' in the stock location. I'm sure shorter mufflers will lead to that raspy sound.
Yeah I guess 3 HP isn't much.
dobey
Total ratings: 371
Report this Post10-08-2015 02:49 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe it sounds "awesome" to you, but not necessarily to others. You also went through a lot of hassle and spent a decent amount of money to get it in there, if I remember correctly. And it is your car. So of course you're a little biased about it.
Lou and Blue
Report this Post10-09-2015 04:00 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, I just like how it sounds, that's all.
dobey
Total ratings: 371
Report this Post10-09-2015 04:13 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Of course you do. I'm just saying that maybe it doesn't solve the problem that solotwo is trying to solve.
You thought it appropriate to give a negative rating for that? (Maybe it wasn't you, but it seems I have another one, and this was the only thread at the top, that I'd replied in, so seems worthwhile to ask.)
solotwo
Total ratings: 62
Report this Post10-09-2015 06:11 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dont worry about it. I am just tired of the noise and daily almost getting a headache from it. Rating system. To me it is a bunch of crap. I have been on this forum since 2002. Never had any ratings until recently and generally I try to give good information and not be negative. But now days if some has his panties in a bunch they will give you a negative rating just because. I think I know where they came from. Like the old saying "what goes around comes around" It will come back and bite them.
solotwo
Total ratings: 62
Report this Post10-09-2015 06:22 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
solotwo
Member since Jun 2002
I have a flowmaster 80 just fits in the space. Way to loud for a daily driver. PO made his own system. Unfortunately he made some tubing to long and it hangs way to low and way to close to the trunk. NOTE none of the exhaust is mounted in rubber! He made a bracket that he welded to the muffler then used some self taping bolts and screwed that in to the crossmember!
[This message has been edited by solotwo (edited 10-09-2015).]
Report this Post10-09-2015 09:05 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lower sound, of course. Less horsepower, yes.
Another sound reduction approach is the exhaust cone but I have yet to use one. Its still a restriction in the exhaust flow.
My 3" in/dual 2 1/2" out trunk friendly Spintech exhaust does the job and is the lowest 14" L muffler that I have tried but its not that soft sounding. My approach is to insulate the bottom of the deck lid and get some sound insulation placed on the inner fender well. With a short exhaust you just can't have it both ways but I would say that building a custom Y pipe and going around the engine would provide the lowest sounding performance exhaust system.
Lou and Blue
Report this Post10-09-2015 09:19 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didnt leave a rating for you at all. Or anyone else for that matter. Thats not the type of person i am.
I respect everyone's opinions.
I would only rate someone (and always with a positive) if I bought something from them on the forum.
[This message has been edited by Lou and Blue (edited 10-09-2015).]
solotwo
Total ratings: 62
Report this Post10-09-2015 09:35 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Less Power. LOL! That is not a problem with the 3800
countach711
Report this Post10-10-2015 04:36 AM Click Here to See the Profile for countach711Click Here to visit countach711's HomePageSend a Private Message to countach711Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got these tips and while they aren't as good as a regular muffler, they made the car tolerable.
http://www.ebay.com/itm/Hed...em5d5d8ddd21&vxp=mtr
solotwo
Total ratings: 62
Report this Post10-10-2015 08:59 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those look like they would give some baffling to the exhaust. PO installed C6 Tips which have some holes but not like these. Thanks
Now I have to get the stinkin exhaust pipes off of the muffler. LOL
[This message has been edited by solotwo (edited 10-10-2015).]
