  Getting a code 22
Getting a code 22 by Mickey_Moose
Started on: 09-23-2015 10:34 PM
Replies: 11 (658 views)
Last post by: Mickey_Moose on 09-26-2015 08:26 AM
Mickey_Moose
Total ratings: 145
Report this Post09-23-2015 10:34 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
88 GT (3.4l crate - swap done a couple years ago, auto)
Code 22, replaced TPS (new AC Delco unit)
Measuring 5v on grey wire at sensor, check black wire continuity to ground and that is good.
Engine off, key on scanner reads 0.13. Scanner reads 0.15 with engine at idle. Checked with a voltage meter and getting 0.156v (engine off)
Original TPS gave the same readings.
Max reading (WOT) on TPS signal wire 4.82v on meter (engine off).
opinions?? Bad TPS (both)?? Check engine light came on after gas stop after a long drive.
edit: to add there is no "adjustment" on either sensor (holes are not slotted) - well I could bend the arm, but shouldn't have to.
[This message has been edited by Mickey_Moose (edited 09-23-2015).]
Report this Post09-24-2015 10:10 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dont remember what code 22 is
Report this Post09-24-2015 11:02 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Throttle Position Sensor (TPS low voltage)
Code 22 indicates a problem with the Throttle Position Sensor.
a dirty connector or broken wire will throw the code.
Mickey_Moose
Total ratings: 145
Report this Post09-24-2015 02:26 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, guess I should have put that in there - but answered above.
Thanks will disassemble the connector tonight and try cleaning the pins - I figure the wiring is good since I read the same voltages at the ECM or right at the connector.
Edit - guess everyone already has a plus from me, so I couldn't add one for offering help.
[This message has been edited by Mickey_Moose (edited 09-24-2015).]
Total ratings: 465
Report this Post09-24-2015 02:59 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're not familiar with this page? ECM Codes
Shame on you.
Total ratings: 465
Report this Post09-24-2015 03:03 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Apr 99
Originally posted by Mickey_Moose:
...will disassemble the connector tonight and try cleaning the pins
Have you tried putting an ohmmeter on it (while disconnected from the harness)? It'll show if there's a bad spot in the windings.
An even easier way to test the TPS is if you have a scanner or use WinALDL. With key on (but the engine not running) you can see the voltage change as you move the throttle through its full range.
[This message has been edited by Patrick (edited 09-24-2015).]
Report this Post09-24-2015 03:49 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Shame on you.
True.
Mickey_Moose
Total ratings: 145
Report this Post09-25-2015 08:55 AM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
...but yes there is a voltage change - the problem is that it is too at the start (FSM says 0.2v).
Update: well looks like the issue is with the TPS sender - fed 5v and ground into the sender, measure output (direct connections to the sender) - reads 0.15v, so I just applied a "plyer mod" to the arm and now it reads 0.21v on the scanner (just over the threshold). See how that goes. that being said, what should the "normal" reading be at idle (or key ON at rest)?
For the record I put the old sender back in and it is now reading 1.8v at key on - so just tossed it.
[This message has been edited by Mickey_Moose (edited 09-25-2015).]
Total ratings: 465
Report this Post09-25-2015 12:11 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
... what should the "normal" reading be at idle (or key off at rest)?
With key "off", wouldn't it be zero volts?
Mickey_Moose
Total ratings: 145
Report this Post09-25-2015 01:28 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
....you sir are correct, my mistake that should have read key ON - fixed.
Total ratings: 465
Report this Post09-25-2015 08:06 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
....that should have read key ON - fixed.
TPS adjustment shouldn't be necessary, but the "ideal" reading would be .5-.6v with the throttle closed.
Mickey_Moose
Total ratings: 145
Report this Post09-26-2015 08:26 AM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree it shouldn't be, but I don't really want to buy another sender just yet - so I will see how it goes with the modification.
Thanks for the info.
