  Can't get the Distributor out of my 85 Iron duke...
Can't get the Distributor out of my 85 Iron duke... by ASCoatings
Started on: 09-17-2015 09:27 AM
Replies: 8 (362 views)
Last post by: ASCoatings on 10-02-2015 05:51 PM
ASCoatings
Report this Post09-17-2015 09:27 AM Click Here to See the Profile for ASCoatingsSend a Private Message to ASCoatingsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Trying to change the whole distributor on my car as the pick up coil went out and it looks like the cap, rotor, and rest of it is all original... So i figured i would just change the whole thing so i don't have to worry about it.
Now i removed the bolt and bracket that hold the distributor on. But i'm having an issue pulling the actual distributor out! It won't budge at all.. are there any tips or tricks to this?
I've never had an iron duke before and on my V6 the thing just popped out with little to no resistance...
Any help would be appreciated quite a bit! This is my daily and it's currently blocking other things at my shop...
Silvertown
Report this Post09-17-2015 09:47 AM Click Here to See the Profile for SilvertownSend a Private Message to SilvertownEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you can get a socket and extension bar on the bolt on the end of the crank, have a buddy move it slowly and pull upwards on distributor. Also make sure your on level ground and wheels chocked. Again slow is the operative word here. You don't want to loosen the crank bolt and definitely don't want to snap it off. Recheck torque on the crank bolt when finished or it could potentially come off. But you should watch this video first of a guy removing his 2.8 distributor first.
http://www.youtube.com/watch?v=9HL_Zd1O9wQ
[This message has been edited by Silvertown (edited 09-17-2015).]
84fiero123
Total ratings: 325
Report this Post09-17-2015 10:25 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Twist it back and forth for a while and then after getting it lose as possible try twisting it while pulling it up at the same time. the prying with a bar will work but if you are afraid of braking the distributer try the twisting pulling.
Remember these things have been in there for decades, usually without ever being touched even, never mind removed.
Steve
[This message has been edited by 84fiero123 (edited 09-17-2015).]
ASCoatings
Report this Post09-17-2015 04:27 PM Click Here to See the Profile for ASCoatingsSend a Private Message to ASCoatingsEdit/Delete MessageReply w/QuoteDirect Link to This Post
yea... the last guy freaking TACK welded it onto the block!
I hate previous owners sometimes..
had to get my grinder out and break the tack weld and the thing pulled right out, which wasn't easy fitting my hand in there, But i'm happy to report the car runs again!
Report this Post09-17-2015 04:33 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Forum!
Total ratings: 466
Report this Post09-17-2015 04:44 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
No wonder it was difficult to remove!
tebailey
Report this Post09-17-2015 06:22 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've seen someone do that with a starter too, sometimes you just want to beetch slap someone.
Total ratings: 461
Report this Post09-18-2015 09:15 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The distributor?!
Some peoples' kids...
Anyhow... Welcome to our obsession!
ASCoatings
Report this Post10-02-2015 05:51 PM Click Here to See the Profile for ASCoatingsSend a Private Message to ASCoatingsEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks!
This is my 2nd fiero. Had a V6 SE a couple of years ago but that got totaled sadly...
I miss the V6...but like the MPG of the little iron duke.
