  IAC clicking noise
IAC clicking noise by FieroCat
Started on: 09-13-2015 01:16 PM
Replies: 7 (864 views)
Last post by: cmechmann on 09-15-2015 09:06 PM
FieroCat
Report this Post09-13-2015 01:16 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was checking and adjusting my timing today and noticed that when I jumpered my A & B terminals on the diagnostic port, the IAC valve started making strange clicky noises like crazy. I unplugged it to be sure and it stopped. For reference, it is a brand new IAC valve. Is this normal?
My Fiero: 1986 Pontiac Fiero GT, V6, 4-speed manual
Report this Post09-13-2015 01:26 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did the clicking stop once you started the engine?
FieroCat
Report this Post09-13-2015 01:30 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not sure, the noise of the engine drowned it out.
Silvertown
Report this Post09-13-2015 01:40 PM Click Here to See the Profile for SilvertownSend a Private Message to SilvertownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anytime you complete that diagnostic circuit you will hear a lot of different noises like relays and the fuel pump and maf sensor kicking on and off. The iac is part of the closed loop after the car has warmed up. You can't hear it while driving because of engine noise. Start the car and open the trunk after the engine has warmed up. If it is making that noise after warm up then I would be concerned.
Total ratings: 290
Report this Post09-13-2015 03:06 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
GM foolishly made shorting A-B do multiple things. One of them is with the key on engine off, the ECM continuously moves the IAC to the closed position. Now that doesn't create a problem of burning out the IAC because the IAC is a stepper motor. The one slight problem that it does present is once you start cranking the engine the IAC is fully closed and that makes the engine hard to start without using the throttle a bit. Once the engine is started the ECM no longer preforms the "close the IAC" function.
On later years (after Fiero) GM dropped this foolish function.
You won't be hearing any noises from the MAF (read above) because the Fiero does not have a MAF.
[This message has been edited by phonedawgz (edited 09-13-2015).]
Report this Post09-13-2015 03:31 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by phonedawgz:
...a problem
Phonedawgz, you're a knowledgeable guy and you're often quite helpful here... but why do you continue to take money (and harnesses) from customers and then terminate all contact with them, as reported HERE? And this is far from the first time it's been reported that you've done this.
Why are you stealing from members of this forum?
This makes absolutely no sense!
[This message has been edited by Patrick (edited 09-13-2015).]
Silvertown
Report this Post09-13-2015 07:33 PM Click Here to See the Profile for SilvertownSend a Private Message to SilvertownEdit/Delete MessageReply w/QuoteDirect Link to This Post
cmechmann
Report this Post09-15-2015 09:06 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
On GM carb cars the short function would drive the IAC out and in, repeat. Kind of looked like the IAC was trying to have sex with the throttle.
