  Distributor upgrade info needed 2.8
Distributor upgrade info needed 2.8 by Spoon
Started on: 09-11-2015 07:07 PM
Replies: 12 (919 views)
Last post by: Spoon on 09-13-2015 12:12 AM
Spoon
Total ratings: 61
Report this Post09-11-2015 07:07 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just received my new dizzy from RockAuto and it the newer style remanufactured by or for AcDelco. There's a sticker on the module that says "WARRANTY IS VOID IF MODULE IS REMOVED". I'm more concerned about whats hidden under the sticker or to make a long story short, am I getting a genuine AcDelco module.
I can't feel any embossed AC logo when running my finger over the label. Just need to know if I've been "hornswoggled" or not.
I think I'm going to peel the label back and take a peek.
Anybody been down this road before.
1986 2.8
Spoon
Kevin87FieroGT
Report this Post09-11-2015 09:56 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Opps
[This message has been edited by Kevin87FieroGT (edited 09-11-2015).]
Kevin87FieroGT
Report this Post09-11-2015 09:58 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kevin87FieroGT
Member since Nov 2010
Don't know about the latest Cardone distributors, but the Cardone(new style)distributor I got had a bad module in 1000 miles of use. I replaced the bad module with an AC Delco and no issues over 6000 miles. I like the newer style distributor over the OEM, just really disappointed in the module Cardone uses. This was on a 2.8 L V6, '86SE.
My88RedGT
Report this Post09-11-2015 10:03 PM Click Here to See the Profile for My88RedGTSend a Private Message to My88RedGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Kevin87FieroGT:
Don't know about the latest Cardone distributors, but the Cardone(new style)distributor I git had a bad module in 1000 miles of use. I replaced the bad module with an AC Delco and no issues over 6000 miles. I like the newer style distributor over the OEM, just really diapointed in the module Cardone uses. This was on a 2.8 L V6, '86SE.
The ICM that came on my Cardone distributor also died after about 2000 miles... I also replaced it with ACDELCO but have only driven it about 300 miles since.
Report this Post09-11-2015 11:01 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't bother the sticker. You should be able to feel the embossing if it's authentic GM. Just remove the module and replace it with one of your liking. Keep the one with the sticker as a backup. I think it sucks that you have to pull the whole distributor and return it if just the module fails. Especially if you're away from home and on the side of the road somewhere. Maybe a week to get a replacement. If the distributor itself ever fails, put the original module back in.
Notorio
Report this Post09-11-2015 11:44 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think the sticker is on there as an improvement (?) in their quality control system. They must feel the type of module they specify and the way they put it on is 'what we like to call the Right Way.' Perhaps they are getting distributors back on warranty when the customer has already tried replacing the ICM. If it was me, I wouldn't take it off.
Total ratings: 291
Report this Post09-12-2015 09:20 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
High resistance in the secondary (spark plug wires and spark plugs primarily) will cause higher than normal voltages to fire the plugs. If the voltage gets too high, that voltage will pierce a hole in the insulation in the ignition coil. That hole will allow secondary voltage to pass into the primary and then into the ICM. The repeated shocking of the ICM will cause the ICM to eventually fail.
Here is a lame video that explains it.
The bottom line - If you have had an ICM fail, you should measure the resistance of your spark plug wires - The max should be 20K ohms per foot. You also need to inspect ALL SIX (not just the easy 3) spark plugs and replace them if the plugs are too worn. Then if either the plug wires or spark plugs were bad, you need to replace the coil. There is no way to test the coil for bad insulation. The test would need to be preformed at working voltages (30,000v) to be of worth. Considering the cost of the ignition coil vs the cost of a tow truck, I'd replace the ignition coil every time I'd replace the ICM.
Never pull spark plug wires on a running engine with electronic ignition. This also will increase the voltage on the secondary and damage the insulation of the coil.
Yes you need to use a good heat transfer compound under your ICM. Without it your ICM will cook and fail. But when you see stories of people who have ran their original ICM (and the rest of the ignition system) for decades, and then all a sudden they had a failure and then they have failure after failure, there is a reason for it.
RWDPLZ
Total ratings: 305
Report this Post09-12-2015 11:13 AM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Definitely a CARDONE, or AC Delco is buying parts from whoever CARDONE's re-manufacturer is.
Spoon
Total ratings: 61
Report this Post09-12-2015 12:26 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay guys thanks for all the info and the amusing video.
I was able to peel off the sticker without ripping it and underneath was absolutely nothing. Just a plain smooth surface. A no-name, a Clone, Orphan, Act-Alike, Copy, Knock-Off, Undocumented Surplus.
So I'd rather not take a chance being left along the road in the middle of the night so I'm going to replace this No-name ICM with the ACDelco one from my old dizzy. I'll put the sticker back on as a reminder and keep the no-namer in the trunk should a limp-home event arise.
Spoon
Kevin87FieroGT
Report this Post09-12-2015 01:30 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dielectric on the mounting screws and fresh thermal paste under for your AC. If I remember correctly, the AC came with paste. You will find Cardone used very little paste. Radio Shack, if you can find one open, has the paste in small tubes. Good to keep a spare paste tube with your new emergency module.
[This message has been edited by Kevin87FieroGT (edited 09-12-2015).]
sardonyx247
Total ratings: 219
Report this Post09-12-2015 07:27 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Again your post really has nothing to do with the question the OP asked,
To help th OP, the star type distributor is not an AC Delco part, the ac delco ones are the finger type, like the stock one. And the stickered modules are never AC either.
[This message has been edited by sardonyx247 (edited 09-12-2015).]
Spoon
Total ratings: 61
Report this Post09-13-2015 12:06 AM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have used the Syringe tubes from Radio Shack. Super expensive but good. I've since ordered them online.
Spoon
Spoon
Total ratings: 61
Report this Post09-13-2015 12:12 AM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spoon
Member since May 2004
Thanks for the tip. So RockAuto sold me a Cardone dizzy instead of an AcDelco. The Cardone looks to be better built.
Spoon
