  LS4 DoD Delete / Valley Cover?
LS4 DoD Delete / Valley Cover? by katatak
Started on: 08-24-2015 06:16 PM
Replies: 7 (1199 views)
Last post by: dobey on 08-25-2015 09:48 AM
katatak
Total ratings: 82
Report this Post08-24-2015 06:16 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Started working on my LS4 swap - I am planning on deleting the DoD. Looking for suggestions for a valley cover. I see several out there that are "lo profile", Vented, etc.
Thanks in advance.
Pat
Darth Fiero
Total ratings: 361
Report this Post08-24-2015 07:58 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Call Scoggin-Dickey and let them know what you are doing. They should be able to tell you exactly what you need, were to get it, or sell it to you if they have it in stock.
https://sdparts.com/
More is more. Less is not enough.
dobey
Total ratings: 371
Report this Post08-24-2015 08:34 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The standard equipment for doing the DoD delete for valley cover, is the LS2 valley cover.
If you plan to relocate the oil sensor elsewhere, there are some valley covers for race engines, which don't have the oil pressure sensor boss.
You must use a valley cover made for a Gen IV engine. A Gen III cover will not work. The LS4 is a Gen IV engine. If anyone tries to sell you a Gen III cover and tell you it's a Gen III engine, they are flat out wrong.
Total ratings: 463
Report this Post08-24-2015 09:08 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Read fieroguru's thread in the Construction Zone.
He did something similar, I think.
Report this Post08-24-2015 09:29 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most of the LS4 guys are using the LS3 valley cover. Its also the recommended one by Scoggin Dickey:
https://sdparts.com/details...arts-center/sdafmd53
[This message has been edited by fieroguru (edited 08-24-2015).]
katatak
Total ratings: 82
Report this Post08-24-2015 09:43 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks all for the replies........
Thinking about locating the OP sensor on the cap at the oil filter. Could I use the valley cover used for a "Carb" application - similar to this one from Moroso!
http://www.moroso.com/eb/ca...rn=&searchTerm=25176
[This message has been edited by katatak (edited 08-24-2015).]
dobey
Total ratings: 371
Report this Post08-25-2015 09:47 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.moroso.com/eb/ca...rn=& searchTerm=25176
You can use that cover, yes. If you do, I'd recommend relocating the OPSU to the rear of the block, by drilling/tapping the same port the OE valley cover uses, as fieroguru did:
CLICK FOR FULL SIZE
This will give a more useful reading than having it located at the filter bypass.
dobey
Total ratings: 371
Report this Post08-25-2015 09:48 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
Member since Sep 2001
He retained DoD, but relocated the OPSU to the rear side of the block, to make room for the LS2 intake manifold.
