  Seat mechanism cover repair
Seat mechanism cover repair by mtgjudge
Started on: 08-19-2015 07:13 AM
Replies: 14 (526 views)
Last post by: VanGTP5000 on 12-08-2017 10:48 AM
mtgjudge
Report this Post08-19-2015 07:13 AM Click Here to See the Profile for mtgjudgeSend a Private Message to mtgjudgeEdit/Delete MessageReply w/QuoteDirect Link to This Post
There was a thread on this topic back in 2009 which I found in a search, but then my heart sank when I realized it was not addressing the kind of repair I needed on my cover.
The plastic "finger" that channels the seat belt across the seat has broken off (due to a careless, large mechanic). I tried using some really strong 2-part epoxy (Araldite, if I remember correctly) only to have it break again. Anyone had any success with another fix, or do I need to suck it up and buy another for $20 plus s/h?
Thanks in advance!
Wesley A. Williams
MAFOA
84fiero123
Total ratings: 325
Report this Post08-19-2015 08:11 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are you talking about a peace of plastic that holds the belt on the upper part of the seat or something else? A picture would be helpful so we know what you are talking about. Because I really am not sure what it is you are talking about
Steve
mtgjudge
Report this Post08-19-2015 08:17 AM Click Here to See the Profile for mtgjudgeSend a Private Message to mtgjudgeEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's the piece down by the driver's waist, left hand side.
I don't know of a way to host a pic. Not very tech savvy, sorry.
EDIT:
See if this works.
Wesley A. Williams
MAFOA
[This message has been edited by mtgjudge (edited 08-19-2015).]
Total ratings: 207
Report this Post08-19-2015 08:39 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The little finger on the inside commonly breaks. The finger fits into the slot on the metal seat bracket and holds the top of the cover tigh5 to the seat.
Perhaps it could be replaced by a properly shaped piece of wire or metal that is epoxied to the inside of the cover.
mtgjudge
Report this Post08-19-2015 08:41 AM Click Here to See the Profile for mtgjudgeSend a Private Message to mtgjudgeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sorry for not being very clear.
The "finger" piece that is broken is the plastic trim piece, visible in the pic.
Wesley A. Williams
MAFOA
Cajun
Report this Post08-19-2015 12:10 PM Click Here to See the Profile for CajunSend a Private Message to CajunEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have in the past repaired the seat belt cover using "Plast-Aid". It's a two-part adhesive for hard plastic. In fact, I used the Plast-Aid to repair the console skeleton and other hard plastic parts!
TopNotch
Total ratings: 60
Report this Post08-19-2015 05:50 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
It would be nice if the Fiero Store or Rodney Dickman would cast some of these out of metal (a cheap pot metal would do). Also, for those of us with t-tops, cast metal end caps would be good too.
fierosound
Total ratings: 287
Report this Post08-19-2015 07:23 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by TopNotch:
It would be nice if the Fiero Store or Rodney Dickman would cast some of these out of metal (a cheap pot metal would do)..
Until then... http://www.fierostore.com/Product/Search.aspx?p=1
mtgjudge
Report this Post08-20-2015 07:14 AM Click Here to See the Profile for mtgjudgeSend a Private Message to mtgjudgeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks to everyone for your advice!
I went ahead and just ordered one.
Wesley A. Williams
MAFOA
jaskispyder
Total ratings: 205
Report this Post08-20-2015 01:13 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound
Total ratings: 287
Report this Post08-20-2015 06:26 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm pretty sure from his description that he means this has broken off due to someone's carelessness...
[This message has been edited by fierosound (edited 08-20-2015).]
mtgjudge
Report this Post08-21-2015 06:17 AM Click Here to See the Profile for mtgjudgeSend a Private Message to mtgjudgeEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound is correct.
Wesley A. Williams
MAFOA
VanGTP5000
Report this Post12-07-2017 09:41 PM Click Here to See the Profile for VanGTP5000Send a Private Message to VanGTP5000Edit/Delete MessageReply w/QuoteDirect Link to This Post
I realize this is an old thread...
The piece being referenced is commonly referred to as the "tang".
I however, am curious how one goes about getting the tab referred to here as the "finger" into the metal slot along the seat recline mechanism. Is there some kind of trick that I am unaware of? I made a few attempts but am afraid to break the plastic tab off as it doesn't seem to line up very easily as I would have expected.
Any help would be appreciated,
-Van
fierosound
Total ratings: 287
Report this Post12-08-2017 08:11 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
How to fix the tab... (thanks Mr. Mike)
http://www.mrmikes.com/fier...stions.htm#sidecover
Or...
https://www.fiero.nl/cgi-bin...d=20130314-1-084868&
[This message has been edited by fierosound (edited 12-08-2017).]
VanGTP5000
Report this Post12-08-2017 10:48 AM Click Here to See the Profile for VanGTP5000Send a Private Message to VanGTP5000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Or...
Maybe I should start a new thread (as I realize this thread is about a fix)...I wasn't asking for a fix. I just want to know how to get the tab back into the slot before screwing down the two screws. It doesn't seem to want to line up and I don't want to break a fresh new one.
-Van
[This message has been edited by VanGTP5000 (edited 12-08-2017).]
