I have been using information from the Forum for a long time but this is my first "build" post. I am a "home" mechanic and all self taught by searching and reading and asking questions if needed but when it came to building my axles for my 6 speed manual swap I was a bit stuck on the process. As I had not found any detailed posts on this I thought it was my opportunity to help other Noobs who need some steps and pictures to make this easier for them. Archie helped me as well with answering my dumb questions so hopefully this will help others who won't have to ask the same ones.
First I laid out all the parts...
- reman axle shafts - part 60-1114 - must not be NEW as those seem to all be a smaller (cheaper) shaft size and will not work for this rebuild. Search for these locally or online but note that I ordered 4 before getting 2 that were correct (returned the others). I ordered the same part each time but I think as they are reman there are many times a slightly different part gets in a box with this part number…painful but eventually I had 2 that matched and were reman originals. Also note, I used 2 short shafts (driver side) as you are only going to use the threaded end for the hub side so you don't need to get 1 long (pasenger side) and 1 short….but you can.
- Axle parts provide by the Archie kit - 1 driver side and 1 passenger side. I assume these are a custom part.
- CV boot grease - I used Dorman 614-066
- CV boot clamps - 20 pcs bag SS Adjustable CV Drive Axle Joint Boot Clamps 48 mm and 120mm (Amazon). You only need 2 large and 2 small but as it was my first time doing this the 20 pcs set was not much more so I went for more.
- Tools - boot clamp crimper (Lisle 30800 CV Boot Clamp Pliers) , Channellock pliers
Steps
- start with 1 of the reman Fiero axles on the threaded end
- Cut off both clamps using side cutter pliers
- Pull boot back towards other boot to get it out of the way
- Clean out some grease to see the lock ring
- Use Channellock pliers to EXPAND the lock ring and at the same time pull the CV joint off the spline
- Remove the boot and place it onto the new F40 style axle
- Add grease as needed into the CV joint
- push the outer CV joint onto the new F40 axle
- Pull the boot over the outer joint and position both for clamping
- Position the clamp, snap it into place by hand into the notches then use the crimp tool to complete the band
- completed first Axle (lower) with old Fiero Axle (upper) with CV joint removed
- completed new CV joint on first Axle
- The first Axle (first try ever) took me just over an hour. The 2nd axle I completed in 15 mins. Both completed axles below.
Hopefully these steps and pics help someone else like so many PFF posts have helped me.
Ken
