  Iron Duke Power Upgrades
Iron Duke Power Upgrades by FieroWillie
Started on: 08-09-2015 04:20 AM
Replies: 18 (1140 views)
Last post by: fierosound on 08-31-2015 12:21 PM
FieroWillie
Report this Post08-09-2015 04:20 AM Click Here to See the Profile for FieroWillieSend a Private Message to FieroWillieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently bought an 88 with the 2.5L and a 5 Spd Trans and I've been wanting to keep the stock engine in there but I want to get about 200Hp out of it, is there any way to do that on the stock block?
cam-a-lot
Total ratings: 97
Report this Post08-09-2015 07:24 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope
That engine belongs in a sewing machine. If you want 200 HP, you will need to put a real motor in there, and likely swap transmissions too. Probably easier/cheaper to just buy an already swapped car, unless you have the skills and tools to do it yourself
Report this Post08-09-2015 08:28 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
/\ /\ /\ What he said. /\ /\ /\
Replacement is your best option.
And a tip - forget horsepower. Torque is King.
TopNotch
Total ratings: 60
Report this Post08-09-2015 01:15 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 88 duke is rated at 98 HP stock. You can put on a later model head (91-93 duke), a mild cam, and big block Chevy roller rockers (I did all that to mine), and get about 120 HP. You'll need a new engine to get 200 HP. If you want the engine to still resemble a duke at that power, look for a Super Duty 4.
FieroWillie
Report this Post08-09-2015 10:47 PM Click Here to See the Profile for FieroWillieSend a Private Message to FieroWillieEdit/Delete MessageReply w/QuoteDirect Link to This Post
What car would I be looking to pull that head off of for a later model head? and do you have any recommendations for a mild cam?
mountainman
Report this Post08-09-2015 11:39 PM Click Here to See the Profile for mountainmanSend a Private Message to mountainmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I recall correctly, there is no roller cam upgrade for the duke. all the performance cams are flat tappet cams. Just seemed like a big step backwards to go back to a flat tappet. I used the cam from the 91 92 duke, it has about .020 more lift than the 88 cam.
I used full roller rockers from Harland Sharp that are spec'd for a chevy straight 6 cylinder engine. You will also need rocker arm studs from and LT1 engine. That's where you set the lash at. Pushrods that I used were from a 429 Ford. You also need the matching 91, 92 intake manifold.
the result is an engine that is very satisfying to drive, great power from 3 to 5k rpm. Will break the speed limit in all 50 states, and still get 33 mpg on the highway.
John M.
FieroWillie
Report this Post08-10-2015 03:08 AM Click Here to See the Profile for FieroWillieSend a Private Message to FieroWillieEdit/Delete MessageReply w/QuoteDirect Link to This Post
John M.
would it be easlier to just swap in a Duke from a 91-93 car? or do I need to part out the 91-93 cam and intake manifold?
edfiero
Report this Post08-10-2015 08:38 AM Click Here to See the Profile for edfieroSend a Private Message to edfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Swapping in a 92 Duke isn't going to get you more than 5-10HP. You need to swap the cam, and port the heads to make more power.
Once you've done that, then you need to reprogram the computer.
Going to a V6 is going to be your best bet for more power. Then you can swap in the V6 computer and wireing harness.
TopNotch
Total ratings: 60
Report this Post08-10-2015 10:31 AM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
John M.
Not true. Accelerated Motion has performance cams for roller cam dukes. That were I got mine.
And I think the Fiero Store has one too.
dobey
Total ratings: 371
Report this Post08-10-2015 01:09 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bolt on a turbo and run it at ~15 PSI.
That should get you close to 200 HP, if it lasts long enough to make it.
mountainman
Report this Post08-11-2015 12:16 AM Click Here to See the Profile for mountainmanSend a Private Message to mountainmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I searched high and low for a performance roller cam. While I've never heard of Accelerated Motion I wish I'd know about them. All the mainstream cam makers had were flat tappets. j
edfiero
Report this Post08-11-2015 01:18 PM Click Here to See the Profile for edfieroSend a Private Message to edfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is Accelerated Motion even still in business? Back when I was looking for a cam for my SD engine, I emailed them at least 4 different times over a period of a month, and never once got a reply. I figured they were out of business, or were doing so well they didn't need my business. I will say they had a lot of good information on their website though.
dobey
Total ratings: 371
Report this Post08-11-2015 01:38 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
FWIW, I've also had difficulty getting e-mail replies from other companies, which are definitely in business. Scat took forever to reply, but eventually did. I never got any reply from Isky. Never got an e-mail reply from Callies either, I had to call them.
Also, Isky seems to have a few roller cams for the duke, on pg 166 of their catalog.
TopNotch
Total ratings: 60
Report this Post08-11-2015 03:59 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you try both cams@amotion.com and doug@amotion.com? I don't recall any trouble reaching them, but it's been a couple of years.
mountainman
Report this Post08-13-2015 12:57 AM Click Here to See the Profile for mountainmanSend a Private Message to mountainmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Isky does indeed have a roller cam for the duke but its a solid roller lifter with monster specs. The smallest has .660 lift. Sorry but that's gonna make for a very bad street motor. I'm sure you'd run into coil bind with stock springs.
If your building a killer race motor, yep I'd look at those cams. But there is no point in trying to make a street duke crank out that kind of hp. It would be more reliable to swap in a 3800.
J M
FieroWillie
Report this Post08-31-2015 09:53 AM Click Here to See the Profile for FieroWillieSend a Private Message to FieroWillieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know where I could source an SD4 without having KRP make one from scratch?
TopNotch
Total ratings: 60
Report this Post08-31-2015 10:39 AM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of our Georgia Fiero Club members had one for sale recently, but I think it's sold now. But watch Ebay and this forum -- they pop up once in a while.
edfiero
Report this Post08-31-2015 12:14 PM Click Here to See the Profile for edfieroSend a Private Message to edfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Contact Forum Member: Legutt. He has several.
fierosound
Total ratings: 286
Report this Post08-31-2015 12:21 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
DarcyJL https://www.fiero.nl/forum/Forum4/HTML/072559.html
Oops - looks like Legutt may have got it all...
Calgary time/temp
[This message has been edited by fierosound (edited 08-31-2015).]
