  3800 supercharger to intake plenum gasket. Sealant as well or no?
3800 supercharger to intake plenum gasket. Sealant as well or no? by deezil
Started on: 08-06-2015 10:22 PM
Replies: 10 (994 views)
Last post by: Darth Fiero on 08-10-2015 07:37 PM
deezil
Report this Post08-06-2015 10:22 PM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
My Superchargers snout has decided it does not like it's bearings anymore.
I have decided to just remove the whole SC and gut it, powdercoat it and rebuild it since it looks a little tired.
The question I have is does the gasket between the SC and LIM need a sealant on both faces or is the gasket as is out of the box sufficient? I will be using the felpro gm #24503911 gasket.
thanks ahead of time!
Darth Fiero
Total ratings: 361
Report this Post08-06-2015 11:40 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
No additional sealant should be necessary. Make sure you clean all of the old gasket material, corrosion, and buildup off the lower intake manifold and the bottom of the supercharger housing prior to installation. Make sure no old gasket is clinging onto the bottom of the snout portion of the blower housing where the single bolt passes through it (to bolt it to the lower intake).
Also make sure you replace the two coolant passage o-rings that rest on the lower intake manifold at the throttle body end, prior to installing the supercharger.
Torque the supercharger to lower intake manifold bolts to 18 ft/lbs. Start at the center bolt on one side and alternate from side to side, working your way outwards in a circular pattern to evenly torque down the blower housing.
More is more. Less is not enough.
[This message has been edited by Darth Fiero (edited 08-06-2015).]
Adjustso3
Report this Post08-07-2015 10:36 AM Click Here to See the Profile for Adjustso3Send a Private Message to Adjustso3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry to jump in here but are the two coolant passages that you speak of for the throttle body the ones that some guys block off with a couple dimes ? Is this a good idea ? I thought I would mention it now because if it's a good idea then it can be done before the SC gets put back on.
Darth Fiero
Total ratings: 361
Report this Post08-07-2015 02:26 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
How do dimes seal up passages? I think I would rather tap and install proper threaded plugs to do that job - if I was going to do it and if it was necessary.
Adjustso3
Report this Post08-08-2015 08:16 AM Click Here to See the Profile for Adjustso3Send a Private Message to Adjustso3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Darth, I have not done this job myself yet but was told that there are 2 passages that should be blocked off under the supercharger. I was told to block them off with a couple dimes and some RTV. I was hoping you would chime back in and comment. From what I was told it is where the two yellow o rings you see when you pull the supercharger off. I guess a little grinding may have to be done to the dimes. I just wanted to point that out since he will have the SC off already. Do you recommend this or is it better to tap the holes and plug them or just leave them alone. I don't mean to hijack this thread but since the supercharger is off I wanted to point out what I was told. I know Darth will recommend if this is a hack or not and is a good idea or not.
deezil
Report this Post08-08-2015 10:02 PM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! Is there a gm part# for these o-rings? I really want to have my ducks in a row when I Go to put this thing back on.
Adjustso3
Report this Post08-09-2015 01:44 AM Click Here to See the Profile for Adjustso3Send a Private Message to Adjustso3Edit/Delete MessageReply w/QuoteDirect Link to This Post
They should come with the gasket. If you look on rock auto they will be in the picture of the gasket. Sorry if I confused anything or gave out wrong info. I'm going to be replacing my LIM gasket from the plastic to the new metal ones and was told by a member to plug the two yellow o rings with a couple dimes and RTV to prevent warm coolant from flowing through the throttle body. I am by no means an engine wizard like a lot of the members here. I'm learning just like you. I was just passing on info before you put your supercharger back on. Hopefully Darth will chime in and clarify if this should be done or not. Once again, sorry for the confusion.
darbysan
Report this Post08-09-2015 11:31 AM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is more to plugging the holes, if you go that direction. You also have to remove the "front Cover" and grind a flow passage ( since you have now blocked it off).
Couldn't find the thread that has pictures of this mod in the LIM Cover, but here's a short blurp from another thread
"The coolant passages to the throttle body keep the body from icing in extremely cold weather. They also flow coolant to the rear head. Granted it is a small amount of coolant but it is still engine coolant. I run them blocked but opened the cover on the lim under the throttle body and channeled it so coolant could flow to the rear head."
Basically you are blocking some flow through the head by blocking off those two ports, and "opening up" the front cover allows that flow to be restored.
BTW, 1/4-20 NPT allen head plugs will also work. Tap the LIM and use some thread sealant on the plugs. If you can find aluminum plugs, even better. Summit racing has them.
'87 GT in process, including GA / Seville brakes, Poly Suspension, '95 3800 Series 1 SC ( 225 hp ) T460e.
deezil
Report this Post08-09-2015 04:31 PM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not blocking off anything?
Adjustso3
Report this Post08-09-2015 11:09 PM Click Here to See the Profile for Adjustso3Send a Private Message to Adjustso3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info Darbysan. Definitely more detail than what I was told. It doesn't sound like it's worth the trouble.
Darth Fiero
Total ratings: 361
Report this Post08-10-2015 07:37 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have never seen any definitive hp gains from dyno or track testing that prove blocking off the coolant passages to the throttle body actually helps.
