  Plastic vs metal gears for headlight?
Plastic vs metal gears for headlight? by rkirkpatrick
Started on: 07-29-2015 05:58 PM
Replies: 8 (474 views)
Last post by: rogergarrison on 07-31-2015 11:42 AM
rkirkpatrick
Report this Post07-29-2015 05:58 PM Click Here to See the Profile for rkirkpatrickSend a Private Message to rkirkpatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pros and cons.
Has anyone used buddy Craig's method for JB weld to eliminate rubber numbers??
Any concern about metal gears allowing motor to get damaged??
86 5 speed 2.5 Iron Duke
Report this Post07-29-2015 06:42 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
This appears that you're referring to the Generation 1 motors. I offer a rebuild service for them, so I have a little experience, plus information from this forum.
In every mechanical device, there is a point in the system that's weaker than the rest. For the Gen. 1 motors, this was the plastic gear. The rubber bump stops in them absorb the shock when the mechanism actually jams up at the end of up or down travel. I have used TFS plastic gears for years, without any problems, then something happened to their molds and the gears were coming out undersized and with concave teeth. This put all the force on 2 very small ares on the ends of the teeth and they would strip in very short order. TFS provided me with replacement gears at no charge but they had the same problem.
They notified their manufacturer and the next batch had some similar problems. This cost me a lot in rebuild labor costs and return shipping, which wasn't offered as compensation. Not wanting to absorb more loss, I have stopped using their plastic gears. I don't know if the problem has been fully corrected. I assume it has since they have put them back in their online catalog.
They also offer metal gears that don't have bump stops to absorb the shock. In my view, this transmits all the stress onto the metal fingers of the drive plate. These fingers become the weakest point in the system, and will likely be the next point of failure in the mechanical portion of the headlight system. If a customer wants these gears used in their rebuild, I will do so, but I only guarantee my assembly process. I prefer the customer purchase gears of their choice, so that portion is outside my warranty responsibility.
Dickman metal gears still use rubber bump stops which work like the original factory bump stops. Irregardless the gear material, the bump stops absorb the energy. The fingers on the drive plate are still the likely weak point, but at least you don't have them slamming metal against metal when they stop.
I've not encountered J & B weld motors, but it is a little harder substrate than the bumpstops. I think that it will also eventually crumble just like the originals. I have, however, found motors with pieces of bolt or threaded rod, hex nuts stacked on one another, and RTV filling the cavities. These were usually in motors I bought at the junk yards. Only the RTV filled motor was a customer's.
If you feel that your motor's gears are in good condition and you only need bump stops, I believe I have a batch that I removed from the motors that got the defective gears. Or I can send you a set of the ones I used to stop the ticking many encountered after rebuilding with plastic gears and rubber bump stops. I don't recommend my bump stops with metal gears, though.
[This message has been edited by fierofool (edited 07-29-2015).]
Report this Post07-29-2015 09:37 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would say that most Fiero owners do not drive their cars daily and keep them as collector or hobby cars. Under these conditions, a Gen 1 rebuilt headlight motor has to last maybe 100 cycles at best to be of value. For instance I drive my Fieros to cruise nights, get together's, to the track and shows. I might get stuck in the rain once or twice a year and most of the events are held during daylight hours. If a headlight motor lasted for 100 cycles that's constitutes a lifetime of use. If your motors are rebuilt to last this long you will probably do a lot of business.
Report this Post07-29-2015 10:20 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I rebuild my motors to last for daily drivers since I have no idea how the customer uses the car. I've designed and had tooling made to reassemble some things similar to what the factory did.
84fiero123
Total ratings: 325
Report this Post07-30-2015 09:04 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Charlie I wonder if you could use the rubber windshield stops, those little triangle shaped rubber blocks that hold the windshield at the right height, you will find them under the lower part of the windshield, or at any auto glass place or parts store that sells windshield replacement material, the urethane or caulk types. They come in all sorts of sizes as well.
Just a heads up for you if you didn't know that already.
If you can't find them I will send you a bunch I have collected over the decades, I keep a mess of them in different sizes and they are easy to cut if need be with just a steak knife. I have got to send off that Moxie this week anyway to Melanie, so if you want to try them I will send some off with the box we have packed already, just haven't had the time to get to the post office..
Steve
[This message has been edited by 84fiero123 (edited 07-30-2015).]
Report this Post07-30-2015 10:07 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think the triangular shape would work because it would put some point of the mechanism against a tip. I know what you're talking about but I've never seen any small enough to fit into the space.
I have done R&D and found an alternate material that replaces some of the softer rubber bump stops. Those softer ones seem to gradually crush and allow the point set in the limiter to make contact again. This causes the motor to re-set or 'tick' as we describe it. My bump stop material is a little higher density, but still absorbs shock.
Ponnari
Report this Post07-30-2015 06:09 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have followed BC's rebuild process and used JB Weld. I used the existing plastic gears that had not stripped.
They all worked for several years until the old gears cracked or stripped on the teath.
My Fiero's are daily drivers, live in the northwest so it gets dark here about 4:30 pm in the winter. So they are always on going home and most of the time going to work
"Because in a split second, It's gone"
Ayrton Senna
[This message has been edited by Ponnari (edited 07-31-2015).]
rkirkpatrick
Report this Post07-30-2015 07:20 PM Click Here to See the Profile for rkirkpatrickSend a Private Message to rkirkpatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. I may do one set with and w/o JB weld
I am also glad the most expect the lights to go up and down more than 100 times before they break
rogergarrison
Total ratings: 551
Report this Post07-31-2015 11:42 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ya 100 cycles on a driver would be 3-4 months tops (if turned on once a day), and only a month in real world use.
