  Rust inside air filter housing
Rust inside air filter housing by dpatterson
Started on: 07-26-2015 06:59 PM
Replies: 8 (1008 views)
Last post by: theogre on 07-28-2015 12:38 AM
dpatterson
Report this Post07-26-2015 06:59 PM Click Here to See the Profile for dpattersonSend a Private Message to dpattersonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know why the bottom of the interior of the air filter housing tends to rust up?
Is it just coming in through the side vent while driving in the rain?
Is there a mod that can alleviate the problem?
Thanks in advance.
Total ratings: 465
Report this Post07-26-2015 07:56 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you aware there are two (actually three) different types of factory air filter housings on Fieros? I'll assume you're referring to the housing for the V6 equipped Fieros.
My guess is that rain water works it's way into the lid of the housing from the top. Perhaps try using a rubber washer of some sort under the nut.
88FieroGT TTops
Report this Post07-26-2015 08:04 PM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney has the gaskets for the air cleaner--there is one on the bottom, and a rope type one for the lid--also check your air hose on the bottom--make sure it is on...
Pat Jones
Total ratings: 465
Report this Post07-26-2015 08:45 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't believe either of those gaskets has anything to do with preventing water from getting into the filter canister. I could be wrong, but IMO rain water is getting into the center of the top lid.
I've had this occur with a GT which was sitting out in the open unstarted for years. I was shocked when I took off the top of the filter canister and saw how much water was sitting in there!
[This message has been edited by Patrick (edited 07-27-2015).]
dpatterson
Report this Post07-27-2015 12:35 PM Click Here to See the Profile for dpattersonSend a Private Message to dpattersonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have to say that I seriously doubt that much, if any, water gets in through the hole in the lid.
The nut that holds the lid in place is flanged and was quite tight.
Kevin87FieroGT
Report this Post07-27-2015 01:00 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Condensation, or moisture from air entering the canister from the fender air intake.
Neils88
Total ratings: 56
Report this Post07-27-2015 01:37 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rust will occur when there is enough mositure in the air.
rogergarrison
Total ratings: 551
Report this Post07-27-2015 02:41 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
It comes in the side intake...especially in a hard rain with the baffle removed. On my Ferrari kit, there is a much bigger quarter panel scoop, and routed dryer duct from it to the air cleaner. In a very hard rain, it would even stall the engine out on the freeway. It would refire just fine after I stopped moving. Even if you have the baffle, water can still get in the can. I always recommend K&N air filters for that reason alone. OEM paper ones always get soaked and swell up like balloons even choking the engine enough to run very rich. The only Fieros Ive seen with nice dry air filters (v6) are ones never driven in the rain. All others have at least some distortion and rust in the can.
Report this Post07-28-2015 12:38 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
take it out.
clean the worse rust, paint flakes, etc.
coat w/ "active" products that convert the rust to paint primer.
paint w/ rustoleum etc.
many love por-15 products.
Many ____ believe the Myth that destroying intake "muffler" help performance. They point to water drain hole and think that's for air flow. Destroying or removing the muffler can/will cause problems driving in wet weather. Even worse for V6 because short pipe to air cleaner.
Most Air filters do not like getting wet. If you have a Shop Vac... Some filters will be wreck by sucking water. (Filter labels say so.) Same for car air filters. Some types won't see the damage right away but damage can cut air flow even after they dry.
