  Help! Simple question
Help! Simple question by Yellow_Formula
Started on: 07-24-2015 03:59 PM
Replies: 19 (550 views)
Last post by: Yellow_Formula on 07-24-2015 10:23 PM
Yellow_Formula
Report this Post07-24-2015 03:59 PM Click Here to See the Profile for Yellow_FormulaSend a Private Message to Yellow_FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Simple question. What is the correct torque for those tamper proof torx screws on the Fuel Pressure Regulator in a V6 Fiero? My Haynes manual says 88 in lbs, and so does the "How-to" page at Autozone.com, but the little paper that came in the box with the new regulator says 15 in lbs. I decided to trust the Haynes, torqued them all to 20 in lbs, then tried to go to 50, but thought to myself, "That seems awfully tight," just as the tip of my driver broke off in the screw (I got it out with a magnet). I'd like to put my car back together! Can anyone tell me for sure? Maybe 88 in lbs is right and the driver tip I was using is crap. But I DON'T want to strip the aluminum fuel rail!
Report this Post07-24-2015 04:14 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I gotta suspect you're quite young and/or inexperienced at working on cars/engines. Tightening stuff like that is usually done without the need for a torque-wrench. Those aren't head bolts or wheel lugs you're snugging down! For something like screws that attach a fuel pressure regulator, the tightness you can accomplish comfortably with a screw-driver type handle is plenty... especially into aluminum.
With whatever you choose to use a torque-wrench on, I hope you're not getting confused between inch pounds and foot pounds.
[This message has been edited by Patrick (edited 07-24-2015).]
Yellow_Formula
Report this Post07-24-2015 04:20 PM Click Here to See the Profile for Yellow_FormulaSend a Private Message to Yellow_FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually, I'm 42, and I've been working on Fieros for 20+ years. And I know what I am talking about. I'm talking about the six tiny T-10 screws that attack the fuel pressure regulator cover to the aluminum fuel rail. If you want to "snug those down" by feel, good luck. I'll use my in lbs (not ft lbs) torque wrench. But thanks for the advice. Can anyone else tell me the correct torque spec?
Report this Post07-24-2015 04:26 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay, I'm willing to learn something I may not be familiar with. Why is it important for those particular screws to be torqued to spec?
tebailey
Report this Post07-24-2015 04:32 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would trust the specs that came with the new regulator. There have been a lot of mistakes in the Haynes and Chilton manuals and there may have been changes in the new regulator also.
Yellow_Formula
Report this Post07-24-2015 04:53 PM Click Here to See the Profile for Yellow_FormulaSend a Private Message to Yellow_FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, I kinda came to the same conclusion. My wrench only goes down to 20 in lbs, so I went with that. Hopefully no leaks.
Report this Post07-24-2015 04:57 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd still like to know. Seriously.
Yellow_Formula
Report this Post07-24-2015 04:58 PM Click Here to See the Profile for Yellow_FormulaSend a Private Message to Yellow_FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Patrick, to answer your question: I may be a bit old fashioned, but I'm not a big fan of fuel leaks in the engine compartment.
Yellow_Formula
Report this Post07-24-2015 05:07 PM Click Here to See the Profile for Yellow_FormulaSend a Private Message to Yellow_FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yellow_Formula
Member since Sep 2014
The next time you're going to tell someone you don't know who may in fact be older and more experienced than you that they don't know what they are talking about, you might want to find out what they are talking about. Otherwise, you just end up looking foolish.
Report this Post07-24-2015 05:07 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm considerably older than you (and probably more "old-fashioned"), but it wouldn't even occur to me to bother using a torque wrench on screws such as those.
I trust my judgement, but I suppose almost 50 years of pulling wrenches gives me that right.
Report this Post07-24-2015 05:09 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Apr 99
Feel better?
Yellow_Formula
Report this Post07-24-2015 05:11 PM Click Here to See the Profile for Yellow_FormulaSend a Private Message to Yellow_FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I'm glad you've never worked on my cars then.
Report this Post07-24-2015 05:15 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe someone who hasn't got a chip on their shoulder can answer my question. I'd really like to know how critical it is for a torque-wrench to be used on fuel pressure regular screws. Thanks.
Yellow_Formula
Report this Post07-24-2015 05:48 PM Click Here to See the Profile for Yellow_FormulaSend a Private Message to Yellow_FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey, you're the one who started with the insults.
To answer your question, on the Fiero (and the 3.4 F bodies) the fuel regulator isn't a sealed unit. A new regulator really consists of a new diaphragm and spring. The diaphragm is then sandwiched between the fuel rail and the upper metal shell. It needs to be torched to spec in the correct cross-cross pattern for the same reason a valve cover or oil pan does--to prevent the mating surfaces from warping and creating leaks.
Report this Post07-24-2015 06:16 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Insults? Oh man... you've got insecurity issues if you think I've been trying to "insult" you.
In all the years I've been on this forum, I don't recall anyone ever asking what the torque needs to be for fuel pressure regulator screws. Therefore, your first post appeared to me to be from someone with limited mechanical experience who perhaps was going overboard being careful. It's not unusual for us to get questions here from 14 or 15 year old kids who are working on their first car prior to getting their driver's license.
I wasn't insulting you. I don't know anything about you! Good gawd, one might think from your reaction that I was watching you work on a car for several hours before suggesting you might be new at this. Don't be so super-sensitive!
Report this Post07-24-2015 06:21 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Apr 99
Seems to me that the "cross-cross pattern" is more critical than an actual torque spec, but I'm definitely not an authority on fuel pressure regulator diaphragms. Thanks for your response.
Neils88
Total ratings: 56
Report this Post07-24-2015 08:27 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yellow_Formula..........# of posts....7 (after arguing for a bit...)
Patrick.......................# of posts....21,900+
Do I have to say anything more?
Report this Post07-24-2015 10:13 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you both done w/ flaming each other...
1. Don't trust Haynes and Chilton. Both a full of errors, missing data, etc. I don't trust them for decades.
1a. Parts stores publish data from whatever. Many things there are useless.
2. If you can't get GM and others Service Manuals... Get Alldata. They get data directly from GM and other car makers. Original AllData is for Pro use, came on Many CD (later DVD) and use Rainbow Dongle for anti copy etc.
GM SM have errors etc too. Many TSB are updates to SM.
Alldata:
1987 Pontiac Fiero V6-173 2.8L
Fuel Pressure Regulator: Service and Repair
1. Remove plenum and fuel rail assembly.
2. Remove fuel inlet and outlet fittings from pressure regulator. Remove and discard gaskets from fittings.
3. Remove pressure regulator bracket attaching screws and the bracket.
4. Remove left and righthand fuel rail assemblies from pressure regulator.
5. Remove base-to-rail connectors from pressure regulator.
6. Reverse procedure to install. Torque attaching screws to 28 inch lbs. and fuel fittings to 20 ft. lbs.
This is all they have there. I DON"T KNOW if above screws are same ones. GM FSM has nothing I can find right now. I think Above is entire regulator, not the cover and diaphragm.
New part can w/ directions then use them. Many parts need different specs.
Most but not all Torque specs are for CLEAN DRY Threads. Dirt, Lube, anti-seize, etc, will void publish torque specs and torque to spec can break things.
MadProfessor8138
Report this Post07-24-2015 10:15 PM Click Here to See the Profile for MadProfessor8138Send a Private Message to MadProfessor8138Edit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe some humor will help......
Torque em down till they snap...then back em off bout a quarter turn....lmao
Sorry,just old A&P humor.......
You should see me give directions....you're either gonna make 3 lefts or you're gonna follow me and turn bout a mile before I do....lol
Yellow_Formula
Report this Post07-24-2015 10:23 PM Click Here to See the Profile for Yellow_FormulaSend a Private Message to Yellow_FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
28 in lbs, not 88 in lbs. Slight difference... Thanks for the info. I'll check out AllData.
(The fact that I don't have many posts doesn't mean I'm inexperienced as a mechanic, only that I don't hang out in the forums)
