  How do I remove the Key cylinder?
How do I remove the Key cylinder? by hetterbr
Started on: 06-26-2015 05:41 PM
Replies: 4 (136 views)
Last post by: Yannsky on 06-28-2015 11:18 AM
hetterbr
Report this Post06-26-2015 05:41 PM Click Here to See the Profile for hetterbrSend a Private Message to hetterbrEdit/Delete MessageReply w/QuoteDirect Link to This Post
1985 GT.
How do I remove the key cylinder for the ignition on the steering column? is there a button or something to push? if so, where.
Thanks
RWDPLZ
Total ratings: 305
Report this Post06-26-2015 06:48 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Remove the steering wheel and start working your way down into the column until you get to it. Typical GM Saginaw column design used for ~20 years
https://www.fiero.nl/forum/F...L/088020-3.html#p111
https://www.youtube.com/watch?v=14sGPdiB250
Monkeyman
Total ratings: 180
Report this Post06-26-2015 11:58 PM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there a video showing the additional steps needed to replace the turn signal/wiper switch?
Wittendorf1986
Report this Post06-27-2015 03:50 AM Click Here to See the Profile for Wittendorf1986Send a Private Message to Wittendorf1986Edit/Delete MessageReply w/QuoteDirect Link to This Post
You have to have a puller to pull the steering wheel off and tear it all apart remember how you pull apart and where everything goes a lot of wires and small parts in there. Another thing leave the key in the new lock cylinder until it all installed
Yannsky
Report this Post06-28-2015 11:18 AM Click Here to See the Profile for YannskySend a Private Message to YannskyEdit/Delete MessageReply w/QuoteDirect Link to This Post
There a how to do on the home page of pff also thereis a thread by fierojazz the column specialist astep by step printable document with tons of pictures
Sorry jazzman not fiero jazz
[This message has been edited by Yannsky (edited 06-28-2015).]
