  Vehicle Speed Sensor (Auto. Trans.), Turns CW or CCW in the Drive select position?
Vehicle Speed Sensor (Auto. Trans.), Turns CW or CCW in the Drive select position? by hdryder
Started on: 06-21-2015 11:58 AM
Replies: 2 (93 views)
Last post by: hdryder on 06-21-2015 05:16 PM
hdryder
Report this Post06-21-2015 11:58 AM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know if the Vehicle Speed Sensor turns in the CW or CCW direction, looking at it from the shaft end with the gear that goes into the Governor, when in the forward motion Drive position?
Otherwise, is there a way to tell of the plastic gear rotation by the angle of the helical gear teeth?
Thank you for the help on this.
[This message has been edited by hdryder (edited 06-21-2015).]
Report this Post06-21-2015 05:00 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
IDK, but rotation direction makes no difference as it is a pulsed signal....
hdryder
Report this Post06-21-2015 05:16 PM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, thank you for that information.
