  Sometimes won't crank when cold. Will crank jumped with a screwdriver.
Sometimes won't crank when cold. Will crank jumped with a screwdriver. by cebix
Started on: 06-15-2015 11:27 AM
Replies: 31 (339 views)
Last post by: cebix on 07-19-2015 06:40 AM
cebix
Report this Post06-15-2015 11:27 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
'85 duke auto.
Okay I've been having this problem recently. When the car has been sitting for a few hours or a day or few _sometimes_ (most of the time it fires up normally) it just won't crank. There's no solenoid click, the lights don't get dimmer, just the "bulb test" lights up okay. Just no reaction at all from the solenoid/starter. Tried wiggling some cables under the dash, tilting the column in different ways - always cranks hot, sometimes won't crank at all when cold. When it's hot it always starts. When I jump the starter with a screwdriver when it wouldn't crank from the key it starts perfectly.
I've removed the starter yesterday, cleaned it up, tested it on a bench - works perfectly. Put it in the car, drove all day - everything was fine. Fired up this morning no problem, wouldn't crank when returning from work after sitting for a few hours.
What should I look into?
EDIT: Battery is new, cranks very strong (when it does). When I mean cold I don't mean low temperatures outside, it was actually about 20 degrees celsius (about 70 F) - just that the engine was cold.
EDIT2: I'm thinking ignition switch. Though it doesn't really fit with hot/cold starting - I guess if it was goind bad it wouldn't start randomly - also hot?
[This message has been edited by cebix (edited 06-15-2015).]
fieromatty
Report this Post06-15-2015 12:23 PM Click Here to See the Profile for fieromattySend a Private Message to fieromattyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like the ignition switch on the steering column. I had this issue once on my 1986 jeep Comanche (same crappy 2.8 engine). Had to replace the ignition switch to resolve the issue.
cebix
Report this Post06-15-2015 02:38 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
I see one more component I haven't checked. The gear selector switch. Could that go bad too? Does that sound more reasonable with the hot/cold symptoms?
I've posted it but just to clarify it's an '85 duke auto.
Mike Gonzalez
Total ratings: 130
Report this Post06-15-2015 04:03 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like the ignition switch out of adjustment to me, have you tried tilting your column up and trying when this happens?
Report this Post06-15-2015 04:48 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Had the same problem when I owned a 2.8L. No start, but with screwdriver jumping the solenoid the engine turned over. In my case I replaced the starter and everything worked fine afterwards. I think that the solenoid was defective. Now a different engine but same switch-still working.
cebix
Report this Post06-16-2015 09:03 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mike,
Yeah, tried tilting like I said in the first post - nothing.
Dennis,
What did "no start" mean in your situation? Did the solenoid click? Or was there no reaction at all?
Report this Post06-16-2015 09:15 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by cebix:
Mike,
Dennis,
I believe that I was jumping the solenoid with the screwdriver so that seemed to prove that it wasn't working. Don't remember hearing any clicks. After changing the starter assembly everything worked fine again and continued to do so. Your problem is either the solenoid or the ignition switch. Both are easy to replace. BTW, Duke and 2.8L use the exact same starter.
cebix
Report this Post06-16-2015 10:05 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Going to check that tomorrow. What about the gear selector switch? It's in series after the ignition switch. Do they go bad too?
EDIT: Again to add, benchtested the solenoid and it works great. Also I don't have any aftermarket alarms or immobilisers, the circuit is straightforward from the service manual.
[This message has been edited by cebix (edited 06-16-2015).]
cebix
Report this Post06-16-2015 01:19 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
cebix
Member since May 2011
Alright... got to the car with a multimeter when it won't crank.
The multimeter shows the solenoid gets about 10V when turning ignition to crank. I'm guessing the voltage drop is due to current flowing through the solenoid. Nothing happens though. On a bench or jumped works great.
Is the solenoid bad or the path has too much resistance?
Total ratings: 291
Report this Post06-16-2015 04:31 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
When you measured this voltage was the purple wire still connected to the solenoid?
cebix
Report this Post06-16-2015 04:50 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah.
Total ratings: 291
Report this Post06-16-2015 04:56 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
10V at the solenoid should be enough to pull it up. If you are up to it you could try replacing the solenoid on your starter.
It's cheaper than a whole starter - http://www.rockauto.com/cat...249208&parttype=4188
cebix
Report this Post06-16-2015 05:08 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will order one, thanks. Tomorrow I'll try to repair mine, look inside, maybe it needs some grease. I have a spare used one but it has repair marks too so maybe it'll work till a new one comes.
rogergarrison
Total ratings: 551
Report this Post06-16-2015 06:47 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Im also going along with the bad solenoid crowd. I dont mess with those, I just replace the whole starter. What usually seems to happen if you fix it the other component fails soon afterward.
[This message has been edited by rogergarrison (edited 06-16-2015).]
cebix
Report this Post06-17-2015 09:15 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have cleaned and greased the starter. It works great on the bench. The brushes are good too. Cranks strong. The solenoid works too on the bench. It just doesn't when the engine's cold and the solenoid is not jumped.
Report this Post06-17-2015 05:18 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If funds are limited, you can try a new solenoid. A starter needs to generate high torque to crank the engine over. It can operate on the bench and not have enough power to turn the engine over but if it works with the screwdriver jumping the solenoid it is likely good......for now.
rogergarrison
Total ratings: 551
Report this Post06-17-2015 05:20 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is all the wiring good and adequate ? If thats all good, id still replace the starter. Maybe you know someone that has one you can try ?
cebix
Report this Post06-18-2015 01:34 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know about wiring. Maybe there's some resistance in the line but I bet on the solenoid. Gonna tear it down and see what I can fix.
As of now it starts again with just the key...
[This message has been edited by cebix (edited 06-18-2015).]
Report this Post06-19-2015 09:22 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the battery cable connection to the starter. The bolt where it connects might be loose.
Tweeter
Report this Post06-20-2015 04:35 AM Click Here to See the Profile for TweeterSend a Private Message to TweeterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a similar issue. It ended up being the Body Ground next to the factory battery location. I used jumper cables to test. Battery to Engine did nothing but connecting an additional body ground fixed the problem. After that I just looked at all the factory grounding points and found the one next to the batter had corroded/rusted.
[This message has been edited by Tweeter (edited 06-20-2015).]
cebix
Report this Post06-21-2015 07:01 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've just had the starter out a week ago like I said earlier and tightened down and sanded all the connections. It was acting like in this thread before I took it out. Ground straps are also good. I'm betting still on the solenoid itself, I didn't have the time yet to get it worked out but I'll post when I'll do.
84fiero123
Total ratings: 325
Report this Post06-21-2015 09:04 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just to say why,
I have had what is called a flat spot, dead spot on the starter in a couple of cars over the last 40 years that did that, hit the starter or solenoid and it would start right up with the key.
But there is also the possibility it is just the ignition switch, not the one you put the key in, the one at the bottom of the steering column bolts may have loosened up or the switch itself could be on its way out. Just take the 4 bolts out of the column that hold it up and drop it onto the seat and you should be able to see if the switch bolts are lose, just by grabbing the switch and seeing if it will move then or when you turn the key.
But it also could be something as simple as a worn out part in the solenoid or starter that when it got hot didn't make contact.
Good luck I hate hunting down electrical problems, I would rather pound my balls flat with a sledge hammer than hunt down an electrical problem.
Steve
cebix
Report this Post06-21-2015 10:41 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've repaired the steering column some years ago and the ignition switch looked good then. I still don't think it's the switch because of the reason that when the engine's hot it _always_ starts.
Also when it wouldn't start from the key and I jumped it for a second (engine didn't start) I tried the key again and it still didn't start. Jumped it for a normal time and it starts.
[This message has been edited by cebix (edited 06-21-2015).]
84fiero123
Total ratings: 325
Report this Post06-21-2015 01:43 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Heat affects different metal differently it is possible when the engine gets hot so does the starter and even the solenoid , the contacts inside may be moving when the engine is hot. That direct connection with a screwdriver may just be all that it needs to make contact, can you see if any of the terminals on the starter are lose?
Steve
cebix
Report this Post06-21-2015 02:33 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope, everything's tight. As I said before, a week ago I cleaned the connections too.
Blacktree
Total ratings: 350
Report this Post06-21-2015 02:49 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like a bad solenoid to me. Although it wouldn't hurt to check the big fat electrical connector on top of the transmission. If that comes loose, the engine won't start, because the wiring for the park/neutral safety switch goes thru there.
cebix
Report this Post06-21-2015 02:59 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
As I said before - there is voltage on the solenoid when turning the key to crank in P or N, so I guess that switch is good.
84fiero123
Total ratings: 325
Report this Post06-21-2015 08:19 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Missed that, more likely forgot it, if you have power to the solenoid then it is most likely the solenoid. and unless you are strapped for cash I would replace both the solenoid and the starter at the same time.
Steve
2002z28ssconv
Total ratings: 51
Report this Post06-22-2015 04:49 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just because I gotta be different... :P
My daughter's 88 2.5 had a similar problem that took me a long time to diagnose. The car would start 95% of the time with no issue. But when it didn't want to, no click, no nothing. Starting it with a screwdriver always worked though.
What it turned out to be was the battery cable. On the + side you have the main cable that goes to the starter. Then there's the smaller wire that runs to the C500 area. The previous owner had replaced the battery terminals with a clamp-on style that cinches down around the core of the exposed cable. The smaller wire was terminated into a ring terminal and it wasn't making a good connection. It was placed between the body of the battery terminal and the plate that gets squeezed by the bolt. I moved the terminal to the outside of the battery terminal assembly so that the ring terminal made contact with the head of the same bolt. With a good connection, no more problems with the starter.
That wire feeds the ignition switch and then the starter solenoid. I would always get good voltage everywhere, all the way to the solenoid on the purple wire but because of the bad connection it wouldn't carry the amperage load across it.
So check the small wire coming from the + battery terminal.
cebix
Report this Post06-22-2015 05:55 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
I redid the connections when replacing the battery a month ago... maybe something has come loose there. Will check it.
cebix
Report this Post06-23-2015 01:21 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got the starter and solenoid rebuilt. Cranks good so far. We'll see how it goes.
cebix
Report this Post07-19-2015 06:40 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
To close the thread I think I can say it was the solenoid. No "no crank" situation yet since the rebuild.
