  Sunroof Seal -- does t really need gasket cement?
Sunroof Seal -- does t really need gasket cement? by oregonfieroguy
Started on: 05-30-2015 08:44 PM
Replies: 1 (666 views)
Last post by: ILVMYGT on 05-30-2015 09:04 PM
oregonfieroguy
Report this Post05-30-2015 08:44 PM Click Here to See the Profile for oregonfieroguySend a Private Message to oregonfieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm replacing the sunroof real, so far so good, got the old one out, and the cleaned the track. The new one seems like it will fit just fine. What are people's experience with using some sort of cement, or glue? I'm inclined to use just a little, maybe a bead all the way around in the middle of the channel. What do you think? Someone already put drain holes in it. Is the sealant to keep water out, or just to keep the rubber molding from moving?
ILVMYGT
Report this Post05-30-2015 09:04 PM Click Here to See the Profile for ILVMYGTSend a Private Message to ILVMYGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put mine back in without any adhesive or glue. It's working just fine without it.
88 GT 5 Speed Black with gray interior
3800 SCII Swap Complete.
Paint Complete
Detailing in Progress
IT RUNS!!
IT'S QUICK!!
"Real integrity is doing the right thing, knowing that nobody's going to know whether you did it or not."
