  Fiero off-road wheels?
Fiero off-road wheels? by jokerb90
Started on: 05-15-2015 07:49 AM
Replies: 11 (856 views)
Last post by: Monkeyman on 05-16-2015 09:24 PM
jokerb90
Report this Post05-15-2015 07:49 AM Click Here to See the Profile for jokerb90Send a Private Message to jokerb90Edit/Delete MessageReply w/QuoteDirect Link to This Post
Working on my buggy, and have a little pocket change --
Any recommendations for junkyard rims that will bolt on (no adapter)
Looking to find the largest that I can run, hopefully will stick out some for larger tires...
jaskispyder
Total ratings: 205
Report this Post05-15-2015 08:02 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
bolt pattern is 5x100. Here are the rims that fit a stock fiero...
Wheels!
BUICK
SKYHAWK, SKYLARK, 88-UP
SOMERSET
CADILLAC
CIMARRON 81-88
CHEVY
BERETTA, CORSICA 87-97
GTU, GTZ, Z-26 89-97
CAVALIER 81-UP
Z24 89-UP
CELEBRITY 82-90
CITATION 80-85
X-11 81-85
MALIBU, CHEVELLE 97-UP
CHRYSLER
LEBARON 86-95
LASER, GTS 85-88
NEW YORKER 86-93
SEBRING CONVERTIBLE 96-UP
DODGE
ARIES, 400, 600 86-88
DAYTONA, TURBO Z 85-93
DYNASTY 88-93
LANCER 85-89
SHADOW 87-94
SPIRIT 89-94
STRATUS 95-UP
LEXUS
ES, 250 90-93
OLDSMOBILE
ACHIEVA 92-97
CUTLASS CALAIS, 82-89
CIERA, FIRENZA
PLYMOUTH
ACCLAIM 89-95
BREEZE 95-UP
CARAVELLE 85-88
LASER 85-89
RS, TURBO 85-89
NEON 5-LUG 95-99
RELIANT, TOURISMO 85-89
SUNDANCE 87-94
PONTIAC
6000, LE 82-90
FIERO, GT 84-88
GRANDAM 85-98 GrandAm wheel's... Yes 85-98 ONLY
SE, GT 85-98
SUNBIRD, J2000 82-94
SUNFIRE GT 95-UP
TOYOTA
CAMRY 86-91
CELICA 92-UP
VOLKSWAGEN
BEETLE 99-UP
CORRADO VR6 92-93
JETTAIII (4CYL) 99-UP
JETTAIII VR6 93-UP
GLX VR6 92-98
GOLF 2000-UP
[This message has been edited by jaskispyder (edited 05-15-2015).]
jokerb90
Report this Post05-15-2015 10:18 AM Click Here to See the Profile for jokerb90Send a Private Message to jokerb90Edit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for the list, was hoping to see s-10 or any small truck. Guess adapters here I come...
fierosound
Total ratings: 287
Report this Post05-15-2015 11:36 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just buy bigger tires... (sorry - don't know the details of Troy's vehicle below)
Calgary time/temp
[This message has been edited by fierosound (edited 05-15-2015).]
jaskispyder
Total ratings: 205
Report this Post05-15-2015 12:12 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for the list, was hoping to see s-10 or any small truck..
Wrong bolt pattern. Fiero uses small car, FWD rims (basically).
Report this Post05-15-2015 12:55 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dont really matter the wheels being big or from a truck, the tire size matters more.
Are you lifting the suspension somehow too?
jokerb90
Report this Post05-15-2015 08:12 PM Click Here to See the Profile for jokerb90Send a Private Message to jokerb90Edit/Delete MessageReply w/QuoteDirect Link to This Post
planning to eventually use Marty Jakolat's lift, if he will sell by itself and I get the $$$. Working on the 4.9 swap, have it installed, need to do all of the plumbing, wires, linkage, etc...
have a slow leaking tire and thought some big wheels might inspire me -- might try stockers but don't know what tires are available for 14 inch rims... will look....
jokerb90
Report this Post05-16-2015 06:22 AM Click Here to See the Profile for jokerb90Send a Private Message to jokerb90Edit/Delete MessageReply w/QuoteDirect Link to This Post
So, options for the 14" are slim, will likely have to go 15 or larger. Wonder how big I can run before metal rubbing....
Monkeyman
Total ratings: 182
Report this Post05-16-2015 09:51 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tires are cheaper for 15" wheels than bigger wheels and big (ish) tires look even bigger on smaller wheels.
FierOmar
Report this Post05-16-2015 10:35 AM Click Here to See the Profile for FierOmarSend a Private Message to FierOmarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most of the stock wheels listed above are relatively narrow. The two widest wheels on the list above are the Fiero GT (15x7) and the Beretta GTZ (16x7). One that isn't on the list is Subaru. However, Subaru wheels generally have much more positive offset than the Fiero GT or the Beretta GTZ wheels, usually betwenn +48-55mm.
Steel wheels are an option, and should be available in a variety of sizes. However, these will generally be a little heavier.
Given that you are looking for off-road use, you will need to consider available tire options. The photo provides an excellent example. I am wondering what gears are being used to push those tall tires.
FierOmar
jokerb90
Report this Post05-16-2015 04:27 PM Click Here to See the Profile for jokerb90Send a Private Message to jokerb90Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, that pic is amazing. My gearing will be stock 4.9, I am hoping the torque monster caddy and its auto will push it along. Perhaps steelies will be the most cost effective.
What do you think is the safest max amount of offset I can get away with? The car will also see road use...
Thinking tire rack might be the best, but not as inexpensive as junkyard...
Monkeyman
Total ratings: 182
Report this Post05-16-2015 09:24 PM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can put a 10.5" wide tire on a 7" wide wheel. It's done all the time. If you want a wider tire, buy a truck. Keep in mind that the bigger the tire, the farther out it will need to be spaced otherwise you'll hit things as you turn.
