  Replacing the dog bone/ uppen engine mount tomorrow. Any Advice?
Replacing the dog bone/ uppen engine mount tomorrow. Any Advice? by coltonandrew
Started on: 04-22-2015 06:25 PM
Replies: 4 (341 views)
Last post by: 85 SE VIN 9 on 04-23-2015 11:39 AM
coltonandrew
Report this Post04-22-2015 06:25 PM Click Here to See the Profile for coltonandrewSend a Private Message to coltonandrewEdit/Delete MessageReply w/QuoteDirect Link to This Post
It looks like a pretty straight forward process to replace the dog bone, but I want to be sure there isn't some voodoo magic rain dance I'll have to do to get it off and put the new one on
JeffGT
Report this Post04-22-2015 07:33 PM Click Here to See the Profile for JeffGTSend a Private Message to JeffGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
If your engine saggs once you remove it your mounts are done for. Probably the most simple straight forward part in existence.
coltonandrew
Report this Post04-22-2015 07:34 PM Click Here to See the Profile for coltonandrewSend a Private Message to coltonandrewEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats what it looked like. A too good to be true part replacement haha
Monkeyman
Total ratings: 182
Report this Post04-22-2015 10:23 PM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
If your engine mounts are good, it's just a matter of taking the old one off and putting the new one on. You might have to push/pull the motor a little bit but nothing you can't do by hand.
85 SE VIN 9
Report this Post04-23-2015 11:39 AM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is this why you want to replace your dogbone?
If so, a new one will do the same thing. At least that's what happened to mine. My other mounts look ok, but something must be wrong. I also have a loose bulkhead manifold, which is probably related. The good news is, replacing the dogbone did do away with some noises.
You'll need access through the triangular panel by the right shock tower.
A spreader/clamp will make it easier.
Trouble is this happened immediately.
I ended up doing this, which has held up about eighteen months.
This car seems to have some mods/work done on the cradle/engine. Maybe things don't fit for a reason.
[This message has been edited by 85 SE VIN 9 (edited 04-23-2015).]
