  Champion Radiator installation
Champion Radiator installation by JeffreyMiller
Started on: 04-10-2015 10:29 AM
Replies: 9 (900 views)
Last post by: Rfe88GT on 04-26-2016 08:40 PM
JeffreyMiller
Report this Post04-10-2015 10:29 AM Click Here to See the Profile for JeffreyMillerSend a Private Message to JeffreyMillerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know what modifications have to be made to the radiator support and brackets for the installation of the champion radiator from Ledfoot Racing part # CC828?
rogergarrison
Total ratings: 551
Report this Post04-10-2015 11:10 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 2 row ones were always direct bolt ins, no mods at all.
Riddick85
Report this Post04-10-2015 11:14 AM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
When I installed mine it was bigger than the stock one but it did fit. You may have to shave down the rubber hold downs a bit with a razor but other than that it's good
JeffreyMiller
Report this Post04-10-2015 11:33 AM Click Here to See the Profile for JeffreyMillerSend a Private Message to JeffreyMillerEdit/Delete MessageReply w/QuoteDirect Link to This Post
The radiator I'm installing is a three core type and I've been told some modifications have to be made. I was just looking for some input from anyone who has used this particular radiator.
Riddick85
Report this Post04-10-2015 11:49 AM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have the 3 core. Like I said just have to play with the rubber a bit and squeeze it in there. Mine has been in there 3 years without a problem
dobey
Total ratings: 371
Report this Post04-10-2015 01:51 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
As mentioned you need to cut the rubber mounts down a little bit. You may also need to enlarge the hole for the fill neck, in the upper bracket.
unboundmo
Report this Post04-10-2015 04:33 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
The filler neck area from the stock bracket is a little smaller than the new neck on the radiator. I had to take my Dremel and cut it open a little more for fitting... I don't remember cutting the bottom rubber on mine though
hnthomps
Total ratings: 50
Report this Post04-10-2015 08:29 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did this a few years ago and do not remember cutting anything on a rubber bumper. There was some mild work on the upper bracket but nothing else. This was for a three core champion. I had a set of installation instructions that I will post if I can find them.
This instruction sheet originally came from the old V8 Archie site IIRC and has written instructions as well as pictures. It is not on the new web site but I think that I may have it on one of my laptops. If so I will e-mail the instructions to you.
Nelson
[This message has been edited by hnthomps (edited 04-10-2015).]
hnthomps
Total ratings: 50
Report this Post04-10-2015 09:05 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
hnthomps
Member since Jul 2003
I just located the procedure and e-mailed it to you. Feel free to thank V8 Archie and post it here if you want. I did not want to try and deal with a mixed photo and text document tonight.
Nelson
Rfe88GT
Report this Post04-26-2016 08:40 PM Click Here to See the Profile for Rfe88GTSend a Private Message to Rfe88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Nelson
Thanks for emailing me the directions
Rfe88GT
