  Seatbelts
Seatbelts by Red88fm
Started on: 12-31-2014 11:55 AM
Replies: 5 (867 views)
Last post by: Patrick on 06-04-2015 07:53 PM
Red88fm
Report this Post12-31-2014 11:55 AM Click Here to See the Profile for Red88fmSend a Private Message to Red88fmEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone used a replacement seatbelt? Any advise on wich one to use. Thanks
Tweeder
Report this Post12-31-2014 01:27 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
+1
86 SE Convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
Total ratings: 199
Report this Post12-31-2014 07:05 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've found the quality to be rather poor for most aftermarket stuff like that. Have you tried the reconditioned ones from the Fiero Store? They are like new basically. Totally clean, even have new plastic bushings.
dobey
Total ratings: 371
Report this Post12-31-2014 07:22 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or just pull one out of a newer model car at the yard that still has a good and fully working system.
Or pull yours apart and replace the bushings and oil it well, so it works like new again (unless the seat belt itself is actually torn or fraying, of course).
PaulJK
Total ratings: 237
Report this Post01-01-2015 05:57 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Whichever ones you use, BE SURE to get both ends. DO NOT assume that one end from this fiero will match with that end from another fiero. In the infinite wisdom of GM, they used different belts throughout the fiero line. It is VERY easy to get belts that won't fit together (male and female ends won't latch together) if you start mixing belts from different cars.
Total ratings: 458
Report this Post06-04-2015 07:53 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good tip, I didn't know that.
