  Removing spray paint branding off Intercooler
Removing spray paint branding off Intercooler by 4thfiero
Started on: 12-10-2014 11:50 AM
Replies: 8 (307 views)
Last post by: FTF Engineering on 12-12-2014 09:49 PM
4thfiero
Report this Post12-10-2014 11:50 AM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys. as u can see in my ecotec build thread. My intercooler was branded via spray paint "AFI" looks kinda dumb. Does anyone know a good easy method to remove black spray paint from an intercooler without harming anything???
rogergarrison
Total ratings: 551
Report this Post12-10-2014 12:49 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rag and lacquer thinner or nail polish remover.
4thfiero
Report this Post12-10-2014 12:53 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome, thanks man
4thfiero
Report this Post12-10-2014 12:56 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
4thfiero
Member since Oct 2012
Would brake clean do it too?
Report this Post12-10-2014 01:33 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You don't know what the black paint is....so your odds are about 50/50. Cheap rattle can paint will come off pretty easily, but not 2 part urethane.
rogergarrison
Total ratings: 551
Report this Post12-11-2014 01:20 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
You dont see much catalyzed spray can paint
If it was a dab of paint stripper would get anything, even epoxy. Brake fluid (ONLY DOT4) will also take off most spray can paint without affecting paint underneath it.
Not knowing what your parts natural finish is, taking off the letters may leave it still visible. A scotchbrite pad or sandpaper might me needed to blend it out.
FTF Engineering
Report this Post12-11-2014 09:27 PM Click Here to See the Profile for FTF EngineeringSend a Private Message to FTF EngineeringEdit/Delete MessageReply w/QuoteDirect Link to This Post
Eastwood has that. They call it their 2K Aero line: http://www.eastwood.com/pai...ro-spray-paints.html
I wasn't sure I was understanding things correctly until I saw a cutaway demo can on the shelf at their store. Really cool idea for someone who needs just a can or two and doesn't want to mess with a gun and compressor.
rogergarrison
Total ratings: 551
Report this Post12-12-2014 11:26 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes SW sells it too. Catalyst is in part of the can and paint in the rest. You do something like pull a pin or something and shake it up good. Trouble is you have to use it all at one time, because the unused amount then catalyzes in the can
FTF Engineering
Report this Post12-12-2014 09:49 PM Click Here to See the Profile for FTF EngineeringSend a Private Message to FTF EngineeringEdit/Delete MessageReply w/QuoteDirect Link to This Post
Eastwoods is a pin you press in on the bottom of the can that releases the catalyst inside.
They say pot life is 48 up to 72 hours at 68 degrees F.
