  MSD Ignition Coil - Which one?
MSD Ignition Coil - Which one? by AustinH
Started on: 11-12-2014 11:31 AM
Replies: 13 (736 views)
Last post by: Francis T on 11-14-2014 01:02 PM
AustinH
Report this Post11-12-2014 11:31 AM Click Here to See the Profile for AustinHSend a Private Message to AustinHEdit/Delete MessageReply w/QuoteDirect Link to This Post
I noticed MSD has two performance replacement spark coils now:
MSD 8226 - $49.99
100:1 turn ratio
.68 ohm primary resistance
4800 ohm secondary resistance
44,000 max voltage
spark duration 300us
peak current 220mA
MSD 5526 - $37.99
85:1 turn ratio
.45 ohm primary resistance
5500 ohm secondary resistance
48,000 max voltage
spark duration 250us
peak current 220mA
Edit: Looks like the 8226 is better because of the longer spark duration and the current. Depending on the ignition, the max voltage may never be reached anyways.
Edit: Autozone says the MSD 5526 voltage is 48000, while Summit says it is 42000. The MSD website does not have any info on the 5526. Manufacturer says 44000...
Edit: Streetfire (5526) IS manufactured in China, and some people says its a lot cheaper looking/feeling.
[This message has been edited by AustinH (edited 11-13-2014).]
Report this Post11-12-2014 01:57 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe it's something stupid like what country the coil was made....
The $50 one is from Mexico
The $38 one is from China
Just a guess!!
[This message has been edited by Gall757 (edited 11-12-2014).]
Ponnari
Report this Post11-12-2014 02:22 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, not a clue. I think Gall757 might be right. I've been using the MSD 8226 for some time now with no problems. Got it on sale at O'reilly's for $24.99, I like it.
[This message has been edited by Ponnari (edited 11-12-2014).]
Joseph Upson
Total ratings: 88
Report this Post11-12-2014 08:18 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually the opposite. The coils vary on output by the turn ratio, more importantly, the more expensive coil has an advantage in an important area associated with the ability to ignite an air fuel mixture under adverse conditions like for instance a boosted application where misfire incidence increases with boost; spark duration, 300 us vs. 250 us for the cheaper coil. Contrary to what is often thought, current is what is needed to resolve a problem with spark blowout and that's why the plug gap is reduced as the initial remedy and why MSD coils alone almost never resolve the issue when used to replace stock coils that can't do the job. As the windings are increased to increase the voltage output, the available current output is going down at the same time. That's why the boost-a-spark module works, it increases the voltage going into the coil resulting in an increase in it's output without a reduction in current to the coil. Go with the greater spark duration which reduces the chance of misfire.
Think about it in terms of torque vs. horsepower
[This message has been edited by Joseph Upson (edited 11-12-2014).]
Report this Post11-12-2014 08:28 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
What is the unit of measure for spark duration?...... us...
Joseph Upson
Total ratings: 88
Report this Post11-12-2014 10:25 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes and it's significant, though small at the speed spark events occur, especially as rpm increases.
On the other hand, there is no benefit to having a performance coil or any coil that delivers voltage output above the stock coil if your ignition demands do not first exceed that of the OE equipment. The reason is because the coil, no matter how many thousands of volts it can deliver, will only deliver enough voltage as required to jump the spark gap. If it doesn't take 40K volts, your coil will never generate it.
fierogt28
Report this Post11-12-2014 11:08 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
MSD 8226 - $49.99
100:1 turn ratio
44,000 max voltage
MSD 5526 - $37.99
85:1 turn ratio
48,000 max voltage
It seems obvious to me that the 5526 is the better superior choice for both cost and performance. Why is it so much cheaper? Is there some disadvantage to it that I'm missing?
Edit: Autozone says the MSD 5526 voltage is 48000, while Summit says it is 42000. The MSD website does not have any info on the 5526. Will look further into it.
Edit: Streetfire (5526) IS manufactured in China, and some people says its a lot cheaper looking/feeling. Nothing on performance.
I'd buy the MSD 8226 because that's what I used on my old 86GT. I remember the part number too.
Difference in price means something too. Summit lists that coil as the GM blaster coil.
fierogt28
88 GT, Loaded, 5-speed.
Ponnari
Report this Post11-13-2014 03:08 AM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for detailing that "Joseph Upson" , very helpful
"Because in a split second, It's gone" Ayrton Senna
Report this Post11-13-2014 09:05 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was asking what was actually being measured there....and what the 'us' stands for...
AustinH
Report this Post11-13-2014 09:34 AM Click Here to See the Profile for AustinHSend a Private Message to AustinHEdit/Delete MessageReply w/QuoteDirect Link to This Post
The units are actually µs, for microseconds.
TONY_C
Report this Post11-13-2014 09:36 AM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is micro Seconds. it is not really a lowercase u, it's actually μ , the Greek letter Mu.
Report this Post11-13-2014 02:20 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
A Ha! Thank you...
So it is gone in a split second....
Francis T
Total ratings: 119
Report this Post11-14-2014 12:56 PM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you're not running higher than stock compression,say 10:1, 11:1 etc pistons or forced induction, the stock coil will be fine. You should however replace all of the ignition related connectors. They are the number one cause of misdiagnosed coil failures.
http://i16.photobucket.com/...ancis44/100_1147.jpg
[IMG]http://i16.photobucket.com/albums/b50/francis4
4/000_0451-1.jpg[/IMG]
trueleo.com
Francis T
Total ratings: 119
Report this Post11-14-2014 01:02 PM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
Francis T
Member since Oct 2003
trueleo.com
