  equal length exhaust ?
equal length exhaust ? by crashmydaytona
Started on: 09-26-2014 11:04 AM
Replies: 19 (658 views)
Last post by: Yellow-88 on 06-24-2024 08:52 AM
crashmydaytona
Report this Post09-26-2014 11:04 AM Click Here to See the Profile for crashmydaytonaSend a Private Message to crashmydaytonaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was showing my exhaust to my dad and he told me that the tail pipes coming out of the muffler should be equal length. The way I am doing it they are not close. It will take some effort to change everything at this point what problems will occur with unequal pipes? HP loss? Bad tone? The exhaust is for a 3800sc.
dobey
Total ratings: 371
Report this Post09-26-2014 11:26 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It mostly will affect tone after the muffler, as most of the exhaust gas will be expelled out of only one side of the piping, rather than equally distributed at the exit. So it will be louder than if they were equally distributed, and the tone will be slightly different (but most people probably wouldn't notice the difference). As for effect on power, it will be minimal if any, after the muffler on a Fiero. Not enough to worry about.
Ken_86gt
Report this Post09-26-2014 11:26 AM Click Here to See the Profile for Ken_86gtSend a Private Message to Ken_86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Due to the nature of our cars a race tuned exhaust would take a lot of effort. Are you running equal length tube headers? If not, dont even think about different length exhaust tailpipes.
dobey
Total ratings: 371
Report this Post09-26-2014 12:32 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Eh? Stock 2.8 exhaust is equal length from muffler exit points to tips. It's not that hard to get a tuned exhaust. Using Y-piped headers designed for a FWD car on a swap in a Fiero makes fitting things a bit more difficult though, as the exhaust dumps right where the stock muffler sits.
As for "race tuned" it's not that hard, but it's not street legal either. Equal length headers with no exhaust after the collectors, is "race tuned" exhaust.
Ken_86gt
Report this Post09-26-2014 12:53 PM Click Here to See the Profile for Ken_86gtSend a Private Message to Ken_86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doby- This isnt for a stock 2.8 car. At this point we dont have any other information as to header type used, exhaust routing, equal length pipes from manifolds/headers to muffler. Since it was mentioned that he is talking about a 3800 we can make assumtions that he is using the stock manifolds other wise it should have been stated. Pictures would have helped as well. You may have been following a build thread that describes what he has done, but it isn't referenced here.
dobey
Total ratings: 371
Report this Post09-26-2014 01:30 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I haven't been following a build thread.
The stock 2.8 does not have equal length primaries or Y-pipe. And the question was only about the exhaust piping after the muffler, so I concentrated on explaining that. Even with equal length primaries and Y-pipe, the effects of equal length after the muffler will be the same; negligible, and primarily will affect the tone and volume of the exhaust sound. It will sound unbalanced, to a trained ear, or when standing between the exhausts, most likely, to not have equal length after the muffler.
Beyond the sound, it will have basically no effect on power, in the Fiero. Less than the margin of error from consecutive runs on a dyno.
crashmydaytona
Report this Post09-26-2014 02:25 PM Click Here to See the Profile for crashmydaytonaSend a Private Message to crashmydaytonaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry for the lack of info the build thread is https://www.fiero.nl/forum/Forum2/HTML/130946.html the first few pictures show the headers I am using and toward the end of page 3 shows my exhaust. using all 3" mandrel bent mild steel with a magnaflow 3" in dual 3" out.
If the HP loss if any is negligible and the tone difference unoticable while sitting in the drivers seat I don't think I will go to the effort of changing things.
If I do change it up do the # of bends have to be equal (that would not be possible) or just the length from the muffler to end of each pipe regardless of bends? Thanks for helping guys
dobey
Total ratings: 371
Report this Post09-26-2014 02:34 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Different bends will affect flow and sound pulses, so they should be equalized as well, if you want equalized exhaust. But yeah, it really won't make any big difference to you, and if you find yourself annoyed by the sound, should be pretty easy to change later on if you have the welding skills for it. I wouldn't bother unless the sound bothers you and you want to try to smooth things out a bit.
Yellow-88
Report this Post05-27-2024 01:17 PM Click Here to See the Profile for Yellow-88Send a Private Message to Yellow-88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi
I know that this is an old thread but it caught my interest. Interesting that no one has mentioned the reason for "equal length headers" in this thread. It's about getting the exhaust gas out of all cylinders equally, nothing to do with sound. So far no one sells them probably because they are extremely difficult to design. I've been playing with a 3D CAD model on and off for a few years and it is really difficult. My design uses 18" x 1.25" primary pipes feeding 24" x 1.75" secondary pipes. After that it's a 2.5" regular Fiero exhaust.
Exhaust is a huge part of engine performance. Tube volume is based on engine size and RPM. Road cars almost never see RPM over about 5K so small diameter long primaries are more realistic for normal cars. The firing order of the V6 lets one split the headers into a "Tri-Y" system making it a good bit (easer) to fit the pipes into a Fiero.
Is any one else looking at equal length header design in real life?
Yellow-88
ericjon262
Total ratings: 67
Report this Post06-04-2024 03:53 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Yellow-88:
Hi
Yellow-88
your ideas are way oversimplified, and I'm not sure I understand what you mean by a "Tri-Y", that's typically a style reserved for V8's and 4 cylinders. the only thing I've seen done on a V6 that could be called mistakenly called a "Tri-Y" would be a system where companion cylinders merge, then the 3 pipes from those merges, merge into one. A few guys have attempted to replicate this on a Fiero after a guy in Taiwan did it to his car. in theory, this would produce a strong scavenging signal in the pipes, and offer some level of increased performance, how much over a typical header isn't clear, as it requires longer primary tubes than a typical header that would bring each bank's 3 cylinders together.
Primary diameter and length have different effects on performance, and while they comprise the volume of the tube, the tube volume isn't really a recognized factor for most exhaust builders, you could install a pipe 1" long with the same volume as a pipe 100" long, and they would have massively different performance.
as far as equal length is concerned, it can have an affect on performance, both positive and negative, but it really comes down to what you can package in the vehicle. I have a Suburban that I'm putting a 454 in, the same header ideas I can apply to that, I would have a much more difficult time applying to a Fiero with a V8, just based on space, and those headers will be built with unequal length headers in a Tri-Y configuration, to hopefully produce a very large gain in low to mid range torque. as someone who has built more than one header, it's not easy, it's not cheap, and it's not a fast process.
Yellow-88
Report this Post06-06-2024 03:05 PM Click Here to See the Profile for Yellow-88Send a Private Message to Yellow-88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yellow-88
Report this Post06-06-2024 03:07 PM Click Here to See the Profile for Yellow-88Send a Private Message to Yellow-88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yellow-88
Member since Feb 2005
During my multiple careers as a designer I’ve learned that the best designs start with “over simplification” and end somewhere near where they started.
The subject of header design can get very complicated, very quickly given the many variables involved. Fortunately the laws of physics don’t break and that removes at least one of those variables.
I think the term “Tri-Y” was originally a marketing term from a header manufacturer in the sixties. “Tri” suggests three. Neither 4 nor 8 divide by 3 so the term shouldn’t apply to 4 or 8 cylinder engines. But it does work nicely with 6 cylinders. 3 into 1 X 2 then 2 into 1.
To over simplify, a multi cylinder engine is multiple single cylinder engines working together. So starting with 1 cylinder is a logical approach. At the exhaust stroke, a high pressure pulse of gas is forced into a pipe open at one end. Because an area of high pressure always moves to one of lower pressure, the gas will exit the open end of the pipe. The ideal design would be to constantly reduce the pressure as it moves toward the open end. The length of the pipe depends on the RPM and displacement of the cylinder. Ideally, when the pulse of gas reaches the open end of the pipe, the next one is entering. Mass in motion tends to stay in motion so the hot gas “wants” to keep going. Yes, simplified but not overly at this point.
Back to the tri-y concept and the 2.8L V6. One can think of the V6 as two 3 cylinder engines running 120 degrees out of phase. One bank of cylinders firing order is 1, 3, 5 and the other is 2, 4, 6. If you merge 1, 3, 5 into a “collector” and 2, 4, 6 into another, you now have 2 exhaust ports instead of 6. From an exhaust point of view, this “looks” like a 2 cylinder engine running at 3 times the RPM of the 6 cylinder engine. Similarly you could merge 1 and 2 into one collector, 2 and 3 into another and 5 and 6 into a third collector. From the exhaust view point, looking at the 3 collectors, you now have a 3 cylinder engine running at twice the RPM of the 6 cylinder engine. 2 into 1 X 3 than 3 into 1. “Tri-Y”.
The physics of it can get deep into fluid dynamics and thermal dynamics but in reality it’s about reducing the resistance of gas movement in an open-ended tube system. There are lots of calculators and formulas published on the subject, but in the end header design is a compromise between the engine and how it will be used. Big engine high RPM needs bigger diameter shorter tubes and small engine low RPM needs smaller diameter longer tubes. “Equal length” is really the most important and by far the most difficult.
Yellow-88
ericjon262
Total ratings: 67
Report this Post06-13-2024 01:20 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yellow-88
it has nothing to do with being divisible by 3, it has to do with there being 3 "Y" pipes in the header. there's alot more going on here than I think you realize.
Neils88
Total ratings: 56
Report this Post06-15-2024 08:49 AM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
One thing not mentioned here is weight. When designing a complex exhaust, the weight increase from the added pipe can render the performance increase irrelevant. Just one more factor to consider in the design.
Yellow-88
Report this Post06-15-2024 10:12 AM Click Here to See the Profile for Yellow-88Send a Private Message to Yellow-88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I stand corrected on "divisible by 3". Add 2 more cylinders to your drawing and it's still "Tri-Y". That's the design I've been working on.
Yellow-88
Report this Post06-15-2024 10:25 AM Click Here to See the Profile for Yellow-88Send a Private Message to Yellow-88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yellow-88
I'm not sure just how much a header system would weigh. Yes less weight equals more useable HP. For me, performance isn't so much about HP, it's about response and engine "feel".
ericjon262
Total ratings: 67
Report this Post06-19-2024 08:56 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
not by commonly accepted nomenclature.
Yellow-88
Report this Post06-22-2024 11:56 AM Click Here to See the Profile for Yellow-88Send a Private Message to Yellow-88Edit/Delete MessageReply w/QuoteDirect Link to This Post
3 into 1 collectors are readily available from "exhaust parts" vendors. There must be a reason for that.
ericjon262
Total ratings: 67
Report this Post06-23-2024 09:36 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
a 3-1 collector is not commonly referred to as a "Y", but as a 3-1 collector. Typically a "Y" or wye refers to the junction of two pipes into one pipe. again, by conventional nomenclature, you have not described a "Tri-Y" you have described an exhaust system that would most likely be described as a 6-2-1, 6 pipes merge into two banks of 3, the two banks of three then merge into 1 pipe. As far as performance goes, the system you're describing isn't really much more than a V6 with headers and a Y pipe, pretty standard stuff.
Yellow-88
Report this Post06-24-2024 08:52 AM Click Here to See the Profile for Yellow-88Send a Private Message to Yellow-88Edit/Delete MessageReply w/QuoteDirect Link to This Post
OK. Whatever one calls it, "standard stuff" or otherwise, why hasn't anyone done it yet? Meaning actual equal length headers.
(" Tri-Y" ) headers are 2 stage systems. In my design the Y pipe is the "secondary" part of the "header", it's not just a Y pipe. Its diameter and length are as important as the primary tubes. The idea is to reduce the amount of tube in the system. The 2.8 optimized for mid range RPM requires 36" X 1 1/4" for each cylinder. 36 feet of tube is both heavy and extremely complicated to stuff into the sideways engine bay. My system splits the 6 cylinder engine into two 3 cylinder engines. Just like all "Tri-Y" systems.
Carefully read my description and forget the" nomenclature".
