  Quick question - what is the purpose of these "thingies" on the door window seals?
Quick question - what is the purpose of these "thingies" on the door window seals? by cebix
Started on: 05-15-2014 04:06 PM
Replies: 13 (464 views)
Last post by: Fiero84Freak on 05-16-2014 05:02 PM
cebix
Report this Post05-15-2014 04:06 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Basically this:
I've always wondered and have no clue how they are even named. What do they do?
NW-Fiero
Report this Post05-15-2014 04:12 PM Click Here to See the Profile for NW-FieroSend a Private Message to NW-FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
based on what I can see... I would say it is a guide of some sort.... sure wish I knew what part of the vehicle I was looking at??
css9450
Total ratings: 86
Report this Post05-15-2014 04:37 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Its supposed to "catch" your glass if you're rolling up the window, just in case for some reason it isn't aligned where its supposed to be.
Report this Post05-15-2014 04:38 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah that guides the window tight at the top. You can see it from farther away here (not my car)
cebix
Report this Post05-15-2014 04:44 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. Another mystery solved.
[This message has been edited by cebix (edited 05-15-2014).]
E.Furgal
Total ratings: 278
Report this Post05-15-2014 05:28 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
it's to keep the window from popping out(away from the seal) at speed.. wind will suck the window away from the seal if they are missing..
mitchjl22
Report this Post05-15-2014 10:26 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've also heard they can help with theft, since the windows roll up and somewhat inward, they prevent a thief from prying the window out away from the body preventing a thief opening the door and stealing stuff.
-Mitch
My Car - 87' GT 3800sc
https://www.fiero.nl/forum/F.../HTML/121571.html#p0
ericjon262
Report this Post05-15-2014 10:29 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
-Mitch
It won't stop a coat hanger...
fireboss
Total ratings: 58
Report this Post05-16-2014 12:09 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or smacking the sunroof latch
KillerFrogg
Report this Post05-16-2014 12:47 AM Click Here to See the Profile for KillerFroggSend a Private Message to KillerFroggEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a '98 Olds Aurora (god I miss that 4.0 N*) and at about 110 the drivers window would start to pull away from the weather stripping, sooner if i was driving into a strong head wind. I do not know the air flow characteristics around the A-pillar, but at highway speeds I have never felt like the windows are trying to pull out. Are these window catches a common thing on cars of this era, as as I have never seen them on anything other than the Fiero. haha
lowtrickry
Report this Post05-16-2014 02:35 AM Click Here to See the Profile for lowtrickrySend a Private Message to lowtrickryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Always wonders what that was my self, what I figured was exactly right.... Yayy me!!!
Report this Post05-16-2014 07:04 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is called an "anti-blowout tab".
Report this Post05-16-2014 09:12 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Oh yeah, my 72 Buick has them, and very common up thru the late 90s for sure.
Fiero84Freak
Report this Post05-16-2014 05:02 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
The blow-out tab is the correct answer.
They were put on Fieros to solve a basic design flaw of the Fiero door; it has no support structure along the tops and sides other than when it seals against the door sill. The pressure that can build up at highway speeds can pull the window away from it's stationary position, and these tabs prevent that. Many two-door coupe type vehicles have some form of this tab - or a variation in it's design - implemented into the design of the upper door seal. It may not be as visible as the ones on Fieros, but the design implementation is there.
