  Clutch pedal becomes stiff while bleeding.
Clutch pedal becomes stiff while bleeding. by FieroCat
Started on: 05-12-2014 10:46 AM
Replies: 11 (3331 views)
Last post by: 84fiero123 on 05-13-2014 07:17 PM
FieroCat
Report this Post05-12-2014 10:46 AM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the process of bleeding my clutch system after replacing both the master and slave cylinders. Lots and lots of bubbles coming out, no end to bubbles in sight... but I noticed that a good way into bleeding, the clutch pedal became ultra stiff and hard to press, and master cylinder was making a spongy scrubbing sound when pressing the pedal in. Is the master cylinder a dud?
And how long does it usually take to get all the bubbles out of the system? They just keep coming, gone through at least 10 cycles of pressing clutch, opening bleeder, closing bleeder and letting clutch out again...
My Fiero: 1986 Pontiac Fiero GT, V6, 4-speed manual
84fiero123
Total ratings: 325
Report this Post05-12-2014 10:57 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you prefill and bleed the master cylinder and slave before installing them, if not it could take days. you really need to prebleed that before installing it. that noise may also be if you didn't prefill it and prebleed it because parts are dry.
best way to bleed these systems is with a pressure bleeder and easily made with a pump pot and a spare master cylinder cap.
http://youtu.be/Mdcn1USVQ-w
Steve
[This message has been edited by 84fiero123 (edited 05-12-2014).]
Csjag
Report this Post05-12-2014 03:22 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have had good luck with the gravity bleed. Raise the drivers side front of the car take out the slave cylinder bleeder screw and keep topping off the master when it get low until you have gone thru 4 refills and then when you top it off the fifth time put the bleeder screw back in. You will still need to press in the slave rod by hand with the bleeder valve open and hold it in then tighten the bleeder screw.
Total ratings: 466
Report this Post05-12-2014 04:14 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by FieroCat:
....master cylinder was making a spongy scrubbing sound when pressing the pedal in.
Did you install the banjo with the loop in the up position?
FieroCat
Report this Post05-12-2014 05:07 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't think to pre-bleed the master or slave, sounds like I better remove them and do that first...
Banjo is installed pointing upwards as directed, so that shouldn't be the cause.
Starting to round off the slave bleeder screw a little from all the opening and closing, are these screws common parts that any store sells or is this a special RD part?
Total ratings: 466
Report this Post05-12-2014 05:13 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Starting to round off the slave bleeder screw a little from all the opening and closing...
Aren't you using a socket, or when you have a tube on the end, a box end wrench?
[This message has been edited by Patrick (edited 05-12-2014).]
FieroCat
Report this Post05-12-2014 05:29 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Box end 12mm. Used the open end a few times and realized that was a no-no, so switched to the box...
FieroCat
Report this Post05-13-2014 04:49 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump: Where would you find a replacement bleeder screw for these? In the case that it does get too rounded off...
Total ratings: 291
Report this Post05-13-2014 05:02 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The slave cylinder needs to be able to more it's piston. If it's piston gets fully extended, and your pedal is properly bled, your pedal will feel like it hit something and it is very hard to press. If you push it hard at that time you will bend you clutch pedal, or the master cylinder push rod.
So make sure the slave piston is not fully extended, and since it needs to be able to move at least 1 1/8" check to make sure the slave piston is pushed back that amount or more.
Leaving the slave push rod out will cause the slave piston to be fully extended.
FieroCat
Report this Post05-13-2014 05:18 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did not think of that! I hope I didn't bend it... would I be able to tell it's bent if the pedal is less than an inch above the brake pedal?
And pushing the slave rod back in the bleed the slave would put it in the proper position, right?
Total ratings: 291
Report this Post05-13-2014 05:29 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the clutch pedal at rest is 1" above your brake pedal then your pedal and pushrod sound fine. If less then inspect both. Yes everything is correct in your bellhousing and throwout linkage just putting the pushrod back in will fix it.
btw when the pedal got hard, you had the bleed finished.
[This message has been edited by phonedawgz (edited 05-13-2014).]
84fiero123
Total ratings: 325
Report this Post05-13-2014 07:17 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
always use a 6 point wrench when bleeding brake or clutch slave cylinders that keeps you from doing, just what you did, available at most parts stores as is the bleeder.
Steve
