  Axle Spindle Washer
Axle Spindle Washer by msrservices
Started on: 05-09-2014 10:52 PM
Replies: 11 (900 views)
Last post by: fieroguru on 09-15-2020 06:24 PM
msrservices
Report this Post05-09-2014 10:52 PM Click Here to See the Profile for msrservicesClick Here to visit msrservices's HomePageSend a Private Message to msrservicesEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of my front hubs did not have the keyed washer behind the nut.
I can't seem to find one (new) locally ..... um or online for that matter.
Rockauto sells a pack of 5 without the key.
How important is it to have the keyed washer for the front axle spindle washer?
[This message has been edited by msrservices (edited 05-09-2014).]
msrservices
Report this Post05-09-2014 11:10 PM Click Here to See the Profile for msrservicesClick Here to visit msrservices's HomePageSend a Private Message to msrservicesEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found one online.
Report this Post05-09-2014 11:46 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
You want the key washer.
Key keeps nut at correct torque.
try www.dormanproducts.com order thru many parts stores.
anthony_86gt
Report this Post03-12-2015 07:53 PM Click Here to See the Profile for anthony_86gtSend a Private Message to anthony_86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know I am bumping an old thread, but does anyone have a part number for the keyed washer? I am having no luck.
tebailey
Report this Post03-12-2015 08:07 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
As long as it's not an 88, the 76-87 Chevettes are supposed to have the same spindles. Might be easier to find in the bone yards, or parts books.
[This message has been edited by tebailey (edited 03-12-2015).]
hobbywrench
Report this Post03-13-2015 09:55 AM Click Here to See the Profile for hobbywrenchSend a Private Message to hobbywrenchEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have made this washer. You will need to find a donor with proper od and smaller ID . You will need a vise , a good round file (chainsaw Swiss will work), a 3 corner saw file and patience. Debur it. Half hour at most. The washer thickness will play into the bearing preload so get a thick donor you can dress down (flat) with 60 grit emery.
Report this Post03-13-2015 01:53 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by tebailey:
As long as it's not an 88.....(snip)
Yeah, you would have a really hard time finding one for an '88.
Report this Post03-13-2015 03:14 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dorman have spindle washers but don't know if have exact ones that fits Fiero. I don't have one to measure.
Never "preload" the nut!
Nut specs are in my Cave, Front Bearings
Dorman 618-026 (RockA listing etc) is rear axle I think, not front spindle. Doesn't have the "key."
FieroVin
Report this Post09-15-2020 10:04 AM Click Here to See the Profile for FieroVinClick Here to visit FieroVin's HomePageSend a Private Message to FieroVinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bumping an old thread I know... but having a hard time finding a replacement front spindle nut. Does anyone have a part number or the proper size for an 87GT?
Vin
1987 Fiero GT, Medium Red Metallic, Lowered
2008 Solstice GXP, Aggressive
1988 - 2006 - The 18 year dry spell between 2-seat Pontiac Excitement was finally over... RIP Pontiac.
cvxjet
Report this Post09-15-2020 12:33 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I cannot find any analog. It appears you need to make a run to the Junkyard; 87 Fiero in Havelock (Since March) and one in Elmira, NY since Sept 3. There is a Chevette in Wilson since June and another in Elmira since Aug 19.
Take a look on "Row 52" to search the JYs for cars....You may be able to get someone to send you a nut....You can call the Fiero Factory in Toney, Al....Phone # 256-285-1988...
I would suggest to every Fiero owner to grab a few spares when there is a Fiero in the JY near you!
Report this Post09-15-2020 02:24 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was able to find these axle washers at my local NAPA store. That was a while ago but they might still have them.
Report this Post09-15-2020 06:24 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just take a washer and do a heavy tack weld to make the tab. Grind it flat, file the sharp corners if needed.
