  Removing tilt lever from column (in car)
Removing tilt lever from column (in car) by nitroheadz28
Started on: 04-22-2014 03:33 PM
Replies: 8 (205 views)
Last post by: nitroheadz28 on 04-22-2014 09:26 PM
nitroheadz28
Total ratings: 94
Report this Post04-22-2014 03:33 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is actually for my Trans Am, but the column is pretty much the same. How the hell do you remove this!? I searched for a while and none of the column write ups cover that step, and the 1 forum post I came across said it just pulls out with a lot of effort. Let me tell you, I put all my weight on it to pull it out and can't get it to budge. Any suggestions? I need it off cause some moron removed the cover that goes around it before I bought the car, now I got the cover from the JY and the hole for the stalk is too small to slide through.
cebix
Report this Post04-22-2014 03:36 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
It just unscrews. Don't pull it or you may damage the threads.
nitroheadz28
Total ratings: 94
Report this Post04-22-2014 04:42 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dzieki!
Can anyone confirm?
Vanet
Report this Post04-22-2014 04:52 PM Click Here to See the Profile for VanetSend a Private Message to VanetEdit/Delete MessageReply w/QuoteDirect Link to This Post
it just un screws. We just rebuilt our tilt column, it un threads counter clockwise.
cebix
Report this Post04-22-2014 05:06 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by nitroheadz28:
Dzieki!
Can anyone confirm?
No problem
nitroheadz28
Total ratings: 94
Report this Post04-22-2014 05:23 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well I tried with some beefy pliers and a paper towel wrapped around it a few times. Ended up marring the lever and it didn't budge, I guess they decided to epoxy mine in or something. Thanks gents.
seajai
Total ratings: 51
Report this Post04-22-2014 07:09 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
They're usually loctited in. Sometimes there are a couple flats on the threaded end for a wrench. If you tear yours up too bad let me know, i probably have a couple laying around and I could send you one.
jscott1
Total ratings: 415
Report this Post04-22-2014 07:38 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it does just unscrew. So the only answer is to mangle it up worse and remove it, then buy a new one.
nitroheadz28
Total ratings: 94
Report this Post04-22-2014 09:26 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
seajai I pmed you.
Thanks again everyone!
