  2.8L CAT. DELETE PIPE
2.8L CAT. DELETE PIPE by RPYRAZOO
Started on: 03-05-2014 07:33 PM
Replies: 9 (1006 views)
Last post by: RPYRAZOO on 03-07-2014 12:56 PM
RPYRAZOO
Report this Post03-05-2014 07:33 PM Click Here to See the Profile for RPYRAZOOClick Here to visit RPYRAZOO's HomePageSend a Private Message to RPYRAZOOEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm removing the cat. converter from my stock V-6 and am wondering where I can get a cat. delete pipe. I've checked around, can't find one on the web. Should I just measure and buy a length of pipe somewhere? Any ideas are appreciated.
Thanks,
Rich
johnguzman1212
Report this Post03-05-2014 07:41 PM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
im fixing to do the same thing this week im buying a pipe post what happens please and how you do it
br1anstorm
Report this Post03-05-2014 07:54 PM Click Here to See the Profile for br1anstormSend a Private Message to br1anstormEdit/Delete MessageReply w/QuoteDirect Link to This Post
The mesh or whatever inside the original cat on my 1988 Fiero Formula disintegrated many years ago, and as a replacement was unavailable (I'm in UK) my local workshop sourced a silencer (you call it a muffler?) of the right length and diameter which fitted the space, and installed that.
The car has run OK ever since, and passes the UK's "non-cat" emission tests. I think the brand-name of the replacement silencer/muffler was "Devil" or something similar.... but I suspect that other names and brands are available in the US which would fit.
Blacktree
Total ratings: 350
Report this Post03-05-2014 08:02 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero Store sells cat delete pipes. I think they call them "performance headpipes" or something like that.
84fiero123
Total ratings: 325
Report this Post03-05-2014 09:30 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
just go to a custom muffler shop, tell them what you need, done in 10 min. if you don't want to bring the cat with you, just get the measurements and pipe diameter, larger or smaller than the original pipe and it will fit inside or outside the pipe.
Steve
zkhennings
Report this Post03-05-2014 10:19 PM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got the right sized length of pipe at like an autozone, the Fiero Store's pipe is stainless I am pretty sure where one from autozone would not be. But yea you could go to virtually any exhaust shop and just ask for the right length and diameter pipe and some exhaust clamps, or weld it if you have a welder. I bet an exhaust shop could do all the work for you and include the pipe for under $100. At least all the places I have gone to before.
Arns85GT
Total ratings: 202
Report this Post03-06-2014 05:00 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Going to a straight pipe at the CAT location is actually a negative performance option. The reason is not the flow. It is the length of the pipe from the Y to the muffler. That is over 6'. As soon as you get to 6' the pulses in the exhaust start tripping over each other and you lose your scavenging effect.
The best thing to do is to hollow out the CAT and put it back. It will behave like a resonator, and break up the exhaust pulses about 3' past the Y. This is a good idea and the cheapest option.
If you read up on exhaust design, you will run into this. Of course you should port the exhaust logs and the Y.
Arn
Blacktree
Total ratings: 350
Report this Post03-06-2014 05:26 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Arns85GT: Going to a straight pipe at the CAT location is actually a negative performance option. The reason is not the flow. It is the length of the pipe from the Y to the muffler. That is over 6'. As soon as you get to 6' the pulses in the exhaust start tripping over each other and you lose your scavenging effect.
I heard of this "six foot rule" before, but am curious about something. You said it's measured from the Y to the muffler inlet, right? So for example, if you have aftermarket headers where the Y is further downstream (the Y in the Trueleo headers is down by the O2 sensor), that would make the Y-to-muffler measurement shorter, yes? I ask, because in my setup the distance from the Y (in the Trueleo headers) to the muffler inlet is just under 6 feet.
Arns85GT
Total ratings: 202
Report this Post03-07-2014 12:40 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Normally the measurement is right from the head. I am saying the Y because the Y changes the pulses a bit, but, if you measure from the rear port or the front port it also changes. If you want to be safe, measure from the head at the farthest port for your 6'.
The resonator cures all this. Be certain that the Trueleo setup falls under exactly the same rule. You need to measure the longest runner from the port to the first location in the exhaust which allows the pulse to dissipate. This distance is affected by the diameter of the pipe also, because the smaller 2" will flow faster than the larger 2.5" due to volume considerations. If I had a Trueleo (which I recommend anyone to buy and use) I would have either a muffler or resonator in the CAT position. BTW I know from experience that the Turbo Muffler design is not the one to use in the CAT position. It just doesn't promote flow. The Flowmaster is better in this application or the Spiraltech. Hope this helps
Arn
RPYRAZOO
Report this Post03-07-2014 12:56 PM Click Here to See the Profile for RPYRAZOOClick Here to visit RPYRAZOO's HomePageSend a Private Message to RPYRAZOOEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for all the ideas. Where can I find SPIRALTECH and is it a muffler or resonator?
Rich
