  Fuel tank - cracked baffle!
Fuel tank - cracked baffle! by notaguru
Started on: 03-05-2014 06:33 PM
Replies: 3 (252 views)
Last post by: notaguru on 03-05-2014 06:58 PM
notaguru
Report this Post03-05-2014 06:33 PM Click Here to See the Profile for notaguruClick Here to visit notaguru's HomePageSend a Private Message to notaguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
'88GT
The radiator shop that's cleaning my tank's interior just advised that a PLASTIC BAFFLE IS CRACKED. The caller said it "MIGHT" be a problem, but recommended going forward with a $145 cleaning job.
I have not seen the crack, and it's an hour round trip.
Do you have any experience with this, and an opinion?
THANKS
LT188GT
Total ratings: 100
Report this Post03-05-2014 06:34 PM Click Here to See the Profile for LT188GTSend a Private Message to LT188GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine is cracked and has been for some time.
wftb
Report this Post03-05-2014 06:43 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Helps if I read the title .There is nothing to worry about if the gas tank baffle is cracked .It will still stop gas from sloshing around .And did you take a peak inside the tank to see what he is cleaning out for your 145.00 ? Chances are pretty good that unless the car has been sitting out in a field for 10 years , the tank will already be clean .I had my tank off for the first time in 7 years last summer and it was spotless inside .
[This message has been edited by wftb (edited 03-05-2014).]
notaguru
Report this Post03-05-2014 06:58 PM Click Here to See the Profile for notaguruClick Here to visit notaguru's HomePageSend a Private Message to notaguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
This '88 sat in the sun, next to a garage, for more than 10 years. It was full of animal nests and windblown junk - in horrible condition. But it had 40k miles on it, so seemed to be worth resurrecting. I pulled the tank because (1) fuel pressure was about 30# and (2) the fuel gauge was inoperative. Both have been fixed. Inspecting the interior of that tank I found a load of crap - hence the cleanout.
THANKS for the input. I'll go forward with that tank -
