  ECM troubles
ECM troubles by greener37
Started on: 02-25-2014 07:53 AM
Replies: 7 (147 views)
Last post by: greener37 on 02-25-2014 02:12 PM
greener37
Report this Post02-25-2014 07:53 AM Click Here to See the Profile for greener37Send a Private Message to greener37Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 87 2.5l auto. When i start the car the check engine light come on right away and goes into a low idle which is weird because they usually have a high idle when started. It will drive but only what seems like half the power. il do the paper clip in the A and B terminal and no codes will flash back even though the check engine light was one when running.
Report this Post02-25-2014 08:23 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Forum!
Before tossing out your ECM, re-set it at the battery junction block. Re-connect after a minute or so.
greener37
Report this Post02-25-2014 08:59 AM Click Here to See the Profile for greener37Send a Private Message to greener37Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just tried it a still same thing engine light comes on but no code will flash back. It just started this when i got the car back from the shop, it had a cracked head so i had a shop replace it being that its cold out an i wasnt going to do it haha. Is there something they could of just missed?
Report this Post02-25-2014 12:06 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just thinking of bad things they may have done......not helpful. How about starting the car with the ALDL jumpered...does it act the same?
greener37
Report this Post02-25-2014 01:26 PM Click Here to See the Profile for greener37Send a Private Message to greener37Edit/Delete MessageReply w/QuoteDirect Link to This Post
alright i just figured it out, would never of thought of it there must be a hole somewhere in the exhaust an it was getting trapped in the engine compartment so it was choking the engine out
Report this Post02-25-2014 01:38 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not a stock air intake?
[This message has been edited by Gall757 (edited 02-25-2014).]
greener37
Report this Post02-25-2014 02:10 PM Click Here to See the Profile for greener37Send a Private Message to greener37Edit/Delete MessageReply w/QuoteDirect Link to This Post
no just a round filter on top the tbi. came like that when i bought it.
greener37
Report this Post02-25-2014 02:12 PM Click Here to See the Profile for greener37Send a Private Message to greener37Edit/Delete MessageReply w/QuoteDirect Link to This Post
greener37
Member since Feb 2014
i still dont get why it wouldnt flash a code though?
