  Has anybody tried using a potentiometer to fix their tachometer? Does it work?
Has anybody tried using a potentiometer to fix their tachometer? Does it work? by PribanicS
Started on: 02-13-2014 12:41 AM
Replies: 4 (976 views)
Last post by: GodSend on 02-14-2014 07:39 PM
PribanicS
From: East Quogue, New York, United States of America
Report this Post02-13-2014 12:41 AM Click Here to See the Profile for PribanicSSend a Private Message to PribanicSEdit/Delete MessageReply w/QuoteDirect Link to This Post
My tachometer reads about 3k rpm at start up (just idling) and when warm, it's around 2k. I wasn't sure if the tach filter was the issue because I read it makes it jumpy but mine appears smooth so to say. There doesn't appear to be any leaks but I wouldn't even think it could reach 3k with a vacuum leak (Also there are no codes). Do you think I may have a tachometer issue? I read this page [url=http://www.howtoalmanac.com/kevin/projects/automotive/tachfix.htm][/url] and he said you could solder a potentiometer on then calibrate it using a frequency generator + oscilloscope. I know people w/ the equipment but I was confused on whether this is the fix I actually need; to calibrating it with the engine like he mentioned. Any replies are greatly appreciated.
[This message has been edited by PribanicS (edited 02-13-2014).]
Total ratings: 466
Report this Post02-13-2014 01:06 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Probably, as it's not uncommon.
Have a look at This thread.
jscott1
Total ratings: 415
Report this Post02-14-2014 02:27 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I do this routinely for the firebird cluster swap into Fieros although the same fix can be applied to the Fiero tach. I have a V8 cluster in my V6 and a V6 cluster in my V8. The only way to get a tach to play nice in those circumstances is to change the resistor. Some folks mess with the capacitor and I tried that and it's waaaay more difficult. With a variable resistor and frequency generator it's child's play to dial it in to the correct value.
Csjag
Report this Post02-14-2014 07:19 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have an oscilloscope but I do have digital wireless tach. Is there room with the car tach plugged in to adjust the potentiometer to the correct resistance?
GodSend
Report this Post02-14-2014 07:39 PM Click Here to See the Profile for GodSendSend a Private Message to GodSendEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did the above fix and worked great for me. Tach is still a LITTLE off the higher you get (at 3500 on tach is about 3300 on diagnostic cable).
Before fix I swapped two different tachometers. Both had similar symptoms . Would read about 1200 idle.. and would QUICKLY climb, where 5000 was just about 2000 in real rpms.
