  Headlight motor question
Headlight motor question by Merlinhaggard
Started on: 02-09-2014 03:22 PM
Replies: 3 (104 views)
Last post by: Merlinhaggard on 02-09-2014 08:48 PM
Merlinhaggard
Report this Post02-09-2014 03:22 PM Click Here to See the Profile for MerlinhaggardSend a Private Message to MerlinhaggardEdit/Delete MessageReply w/QuoteDirect Link to This Post
The plastic gear in one of my motors is gone. I have another motor that works fine but it only has red and black coming out of it. Not the blue. Can I use this at all or should I just buy the new gear.. I would like to use the new one if possible. Thanks..
Total ratings: 154
Report this Post02-09-2014 06:59 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have the early Generation 1 motor. It has 3 wires, including the blue. The later Generation 2 motor will not work on the Generation 1 harness. Rebuild your motor using Rodney Dickman's metal gears. To the best of my knowledge, the Fiero Store's plastic gears still have problems and aren't holding up more than a month or so. Same goes for FieroJon's. He gets his from The Fiero Store or the same manufacturer.
Total ratings: 202
Report this Post02-09-2014 07:46 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
x2 for Rodney Dickman.
You CAN always upgrade the entire headlight system to the Gen 2 (used in 1987-1988) which isn't too difficult, it just requires a few relays and a lighting module... and of course, the new motors. Everything else is the same from what I can tell.
Merlinhaggard
Report this Post02-09-2014 08:48 PM Click Here to See the Profile for MerlinhaggardSend a Private Message to MerlinhaggardEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ordered the metal geaqr. Thanks
