  Aluminum Lug Nuts??
Aluminum Lug Nuts?? by ILVMYGT
Started on: 02-07-2014 12:26 PM
Replies: 12 (1197 views)
Last post by: Steven Snyder on 02-11-2014 12:48 AM
ILVMYGT
Report this Post02-07-2014 12:26 PM Click Here to See the Profile for ILVMYGTSend a Private Message to ILVMYGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone used aluminum lug nuts? I would like to get a lug nut that is 50 mm long and am not finding what I want in steel. So what are your experiences with aluminum lug nuts? The lug nuts are Ultra High Strength Aluminum, but don't list a specific specification.
88 GT 5 Speed Black with gray interior
3800 SCII Swap.
Paint in Progress
IT RUNS!!
IT'S QUICK!!
"Real integrity is doing the right thing, knowing that nobody's going to know whether you did it or not."
dratts
Total ratings: 118
Report this Post02-07-2014 12:59 PM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know of any aluminum that is as strong as steel. Not to mention corrosion when steel and aluminum are in direct contact. jmho.
E.Furgal
Total ratings: 278
Report this Post02-07-2014 01:05 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
you try summit racing, gorilla lug nuts..
I'd not trust alum for lug nuts.. for long term use.. they are more forgiving for a race car that they'll get used once and then chucked
Lou6t4gto
Report this Post02-07-2014 06:52 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
In my opinion. a dangerous Idea.
Custom2M4
Total ratings: 114
Report this Post02-07-2014 07:51 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
You can get an open ended tuner lug... It might be aluminum with a steel threaded insert?
uhlanstan
Total ratings: 427
Report this Post02-07-2014 08:58 PM Click Here to See the Profile for uhlanstanSend a Private Message to uhlanstanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many Porsche come from the factory with aluminum nuts,, some racing association allow aluminum nuts
they are great for States that have a lot of dogsled,igloo favorable weather
they are perfectly safe ,,my experience is that 90% of men fear them!! steel ? aluminum ?,no contest
I do no like them if you change wheels a lot
use a small amount of grease or never seize/ a problem with steel lug nuts ia mechanic hammer them home
with an air wrench
there are 50,000 steel lug nut failures for every aluminum lug nut failure
you can not strip/break your studs using aluminum lug nuts
the fact that Porsche used aluminum lug nuts tells you all you need to know
100 ft pound of torque scares me !! find out how tight you can torque them ??
Of course I favor any thing that lowers the weight the crankshaft has to turn,increasing performance & efficientcy
doublec4
Total ratings: 150
Report this Post02-08-2014 05:22 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had aluminum tuner lugs on my last Honda civic and they worked out just fine through all Canadian seasons. I recently removed them and they showed no signs of corrosion or wear. I was impressed for a $40 eBay purchase.
Total ratings: 198
Report this Post02-09-2014 08:55 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
My Porsche 944 had some really light-weight lug-nuts... don't remember what they were made of.
ConvictedRedneck
Report this Post02-09-2014 10:22 AM Click Here to See the Profile for ConvictedRedneckSend a Private Message to ConvictedRedneckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would recommend looking at Muteki lug nuts. They're made in Japan and are a lightweight, high strength steel. I believe they would have the style you're looking for. I've had them on my car for about 2 years now and have not had any issues.
dobey
Total ratings: 371
Report this Post02-09-2014 11:02 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Muteki? Or Motegi?
Never heard of Muteki.
rogergarrison
Total ratings: 551
Report this Post02-09-2014 12:23 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had to cut out the hoods on my SuperBee that was regular steel, and the hood on my Magnum that was aluminum. The steel was a 30 min job with a jig saw. The aluminum one took 2 hours and required a jig saw, cut off wheel, sawzall and air chisel. I had to cut some steel wheels off a car that took all of 5 mins, and another I had to cut off 2 aluminum ones that took me an hour. So Ill go with some aluminums are tougher than steel. I will agree with 2 different metals. Ive had cars with aluminum wheels that corroded at the center hole and I had to beat them off with a sledge hammer after I took off the lugs.
Lou and Blue
Report this Post02-10-2014 10:08 AM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Search on eBay for sickspeed tuner lug nuts. I think mine are 60mm even. Aluminum yes.
Louis Duet
Baldwin, Long Island, NY
"Blue" <= '85 Fiero GT
Stock V6---Stock everything. Trying to keep it 'mostly' that way.
"Boo" <= '81 Delorean DMC-12
VIN #5835
Stock PRV engine
Robertson Equipped
Neiland/Delman Engineered
Carbed and loving it! (Peugot 604 manifold) ---"Sorry purists"
Steven Snyder
Total ratings: 106
Report this Post02-11-2014 12:48 AM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Porsche has used aluminum lug nuts in the past, but they use a 14mm thread size, so they're bigger and stronger. I've never heard of any cars with 12mm studs and aluminum lug nuts, but some may be available in the aftermarket. Not a great idea.
