  91 3.4l manual transmission PROM
91 3.4l manual transmission PROM by pdemondo
Started on: 02-02-2014 10:29 PM
Replies: 1 (115 views)
Last post by: phonedawgz on 02-03-2014 12:34 AM
pdemondo
Report this Post02-02-2014 10:29 PM Click Here to See the Profile for pdemondoSend a Private Message to pdemondoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where can I get a PROM for a manual transmission 91 twin cam V6? The engine I am using came out of a 91 Grand Prix with an auto transmission but I have it wired up and mated to a 5 speed in an 88Gt now.
Total ratings: 291
Report this Post02-03-2014 12:34 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
$45 for the stock PROM with the VATs if equipped disabled and a solder in socket.
BCFA 91 W-car 3.4DOHC 5 speed
Note - this is for the PROM only, not the MEM/CAL. You will have to cut the legs off of the stock chip and solder the socket in place. Easy if you have a fine point soldering iron and fine solder.
http://www.eecis.udel.edu/~...730-vs-165memcal.jpg
I use my dremel and cut the legs right next to the body of the chip. I then insert the socket so the legs of the socket are on the outside of the PROM leg stumps. I then solder each carefully not to bridge the pins. It looks something like this -
If you want you can send the MEM/CAL to me and I can modify it with the socket for $30.
Otherwise you can use the Moates socket adapter -
email me at gofast@reddevilriver.com or just paypal me there.
[This message has been edited by phonedawgz (edited 02-03-2014).]
