  Clutch master Cylinder question
Clutch master Cylinder question by 4thfiero
Started on: 01-30-2014 09:42 PM
Replies: 2 (138 views)
Last post by: TriumphFetish on 01-31-2014 11:54 AM
4thfiero
Report this Post01-30-2014 09:42 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the clutch master is leaking a little, (inside the car) is there a way to fix that, or just get a new master cylinder?...if so which one would u guys recommend?...2 one ive gone through in 4 years
Dodgerunner
Total ratings: 323
Report this Post01-30-2014 10:56 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Which master do you have?
Is your push rod straight so that it pushes on the piston straight?
Is the loop on the push rod installed up or down?
If it's the first gen master with the output in the middle I'd try a rebuild myself. Look up a 89 Jeep Cherokee master rebuild kit.
I've use them for rebuilds. Hardest step in doing it is getting the piston seal past the snap ring groove. I wrap the seal with ribbon with I install. Dental floss might also work well.
[This message has been edited by Dodgerunner (edited 01-30-2014).]
TriumphFetish
Report this Post01-31-2014 11:54 AM Click Here to See the Profile for TriumphFetishSend a Private Message to TriumphFetishEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only master I'd use is Rodneys. I think he sells a rebuild kit using the upgraded double seal system as well.
