clutch 3.8sc swap by Jeb Stuart
Started on : 01-29-2014 05:25 PM
Replies : 10 (301 views)
Last post by : dhen on 02-04-2014 08:38 PM
Jan 29th, 2014
Jeb Stuart Junior Member Posts: 9 From: Decatur, GA Registered: Oct 2013
My clutch spins when given too much peddle espeially at low RPMs. Has always done this but now more so. Any recommendations? Thanks, Jeb
05:25 PM
mattman134 Member Posts: 643 From: Buford, Ohio Registered: Dec 2009
Your clutch is slipping form the sheer train-like low-end torque that the 3800SC makes. What clutch are you using?
05:30 PM
can't remember the manufacturer or type but a stage II clutch. It was about 4 years back.
05:43 PM
John DeHaan Member Posts: 22 From: Wilsonville, Or, USA Registered: Oct 2013
Time for a new, stronger, clutch.
06:01 PM
jaybug56 Member Posts: 379 From: Cleveland Tenneessee Registered: Jan 2010
Spec 3+
06:58 PM
Yes, a stronger clutch but any recommendations on a type or manufacterer. It lookd like westcoast fiero is the only one who sells a clutch strong enough
08:28 PM
Jan 30th, 2014
kikinz24 Member Posts: 729 From: OHIO Registered: Jun 2010
Go with a spec. Stage 3+ best clutch I ever ran and ive been through a variety of different brands through the years.
02:03 PM
Feb 3rd, 2014
Thanks - I think I will go w a Spec stage 3+ Jeb
09:22 PM
dhen Member Posts: 50 From: Registered: Nov 2013
Stupid question, but do they make Spec 3 clutches for the F-body flywheel? Where's a cheap place to order one?
10:35 PM
Feb 4th, 2014
darkhorizon Member Posts: 12279 From: Flint Michigan Registered: Jan 2006
The clutch you want will depend on what transmission you have, but a properly modified Fbody flywheel will mount a stock fiero clutch.
12:27 PM
Thanks. This will be for an F23 transmission. Is there a make/model that I can ask for to get the clutch?
08:38 PM
