  Spindle, RF, stock height, where to find?
Spindle, RF, stock height, where to find? by 85 SE VIN 9
Started on: 01-26-2014 09:40 AM
Replies: 9 (156 views)
Last post by: 85 SE VIN 9 on 01-27-2014 08:37 PM
85 SE VIN 9
Report this Post01-26-2014 09:40 AM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
85 GT 2.8, the right front spindle has ruined threads. The left spindle is available from TFS, but can't find right anywhere so far. 14 inch wheels, not planning any drop.
tesmith66
Total ratings: 135
Report this Post01-26-2014 11:11 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Post in the mall or hit the boneyard. 85-87 are all the same. I believe 84 was different. 84 Had different lower control arms and a larger turning radius. 88 is also different.
1986 SE Aero coupe.
85 SE VIN 9
Report this Post01-26-2014 11:45 AM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a couple inquiries out including one to the Fiero Factory.
Lou6t4gto
Report this Post01-26-2014 01:02 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Contact Kevin, WickedfieroGTP, (member here) he can help you.
85 SE VIN 9
Report this Post01-26-2014 09:06 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Apparently the spindles are the same as the Chevette. Unfortunately they're all lowered also.
Total ratings: 237
Report this Post01-27-2014 11:43 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
85 SE VIN 9
Report this Post01-27-2014 07:44 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent! One is about half an hour from work. Before I call a place called "U-Pull" and ask this dumb question, does the fact that the part is listed, with a stock number, mean it's already pulled and they could just ship it to me? I might not want to pull a part in sub-zero weather.
Report this Post01-27-2014 07:47 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You never know. Yards run their businesses all kinds of ways. If I had to guess, it would seem that the part could not get a number if it was still in a car.
tebailey
Report this Post01-27-2014 08:04 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where are the lowered spindles, I'd like to find a set for my 84.
85 SE VIN 9
Report this Post01-27-2014 08:37 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Gall757 yeah, that was my thinking. I'll try email.
Um, the trouble with browsing. I think Summit Racing, Amazon, everywhere I searched using "Fiero right front spindle," "front spindle," and so on. You do have to specify and watch out for the more common rear spindles, spindle nuts, porch spindles, and all sorts of spindle parts that don't have much to do with "Fiero front spindles." The Chevette spindle might be a good way to search because I don't think they had a rear spindle. From what I understand they are otherwise the same, but generally cheaper.
