  Fuel Pump Noise
Fuel Pump Noise by Steel88GT
Started on: 01-25-2014 12:51 PM
Replies: 6 (293 views)
Last post by: hnthomps on 01-26-2014 11:56 PM
Steel88GT
Report this Post01-25-2014 12:51 PM Click Here to See the Profile for Steel88GTSend a Private Message to Steel88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have replaced my fuel pump twice already in my 88 GT and it is still making noise when car warms up. I was doing some research on line and I found that a faulty fuel pressure regulator can cause issues with the fuel pump. Can this be the source of my problems or have I been unlucky and purchased two bad fuel pumps? One pump was a Delphi and the other a AC Delco.
Total ratings: 290
Report this Post01-25-2014 02:50 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fuel pumps make noise.
Joseph Upson
Total ratings: 88
Report this Post01-25-2014 04:35 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it is unusually loud the regulator could burn it out if the pressure is too high and it's a cheap pump. Although normally, higher pressures result in a rich condition, the amount of additional fuel flow is proportional to the injector size, smaller injectors deliver a smaller % of excess fuel and may not necessarily give an ominous sign there is a problem. I did a turbo 1.8L swap into a Fiero years ago that had that problem. At near the end of my 30 mile commute going and coming my new pump would start to wind down apparently due to over heating from high pressure due to a bad regulator. A high quality non race fuel pump is not easily heard with the motor running and proper insulation.
Phil
Total ratings: 154
Report this Post01-25-2014 05:06 PM Click Here to See the Profile for PhilSend a Private Message to PhilEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a fuel that would make a rather loud noise at times - turned out to be a leaky pulsater unit (the kind that fits inside the tank).
Csjag
Report this Post01-25-2014 06:11 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just installed a new bosch rotary upgrade pump from rock auto in a duke and can hardly hear it. I have one on order for my 85 GT I just bought and when I put it in I will remove the pulsator if there is one there, its not needed with the rotary pump.
Steel88GT
Report this Post01-25-2014 09:04 PM Click Here to See the Profile for Steel88GTSend a Private Message to Steel88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the input. I will check to see if I have a bad regulator and take it from there.
hnthomps
Total ratings: 50
Report this Post01-26-2014 11:56 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently installed a DW 200 (255 lph) pump on a 3800 SC Series II project and it is very quiet. I also like the three year "no fault" warranty. For a $90 price this is an excellent pump IMHO.
Nelson
