  What do these codes mean ? OBD2
What do these codes mean ? OBD2 by Lou6t4gto
Started on: 01-21-2014 11:34 AM
Replies: 3 (268 views)
Last post by: conan469 on 01-21-2014 01:36 PM
Lou6t4gto
Report this Post01-21-2014 11:34 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before removing the 3800SC / Automatic 4t65e-HD from a 1997 Riviera, I checked for codes. The car always started perfect but had NO Power. Now the engine is completely rebuilt, EXCEPT for the sensors. So maybe these codes will say which ones I need to replace.
U480 menu 1.DTC DTC 02 IM no fault 01 pend 01 PO 305 01/02
Anyone ? Thanks
Total ratings: 260
Report this Post01-21-2014 11:41 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Misfire cylinder #5. Check plug and plug wire for that cylinder. If that doesn't fix it, swap the injector with another cylinder to see if the misfire follows the injector.
Lou6t4gto
Report this Post01-21-2014 11:46 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
the engine is sitting on the cradle already rebuilt so I can't do that. I was under the impression that it was something about the MAF ?( Maybe I should send out the injectors for rebuild)just to be sure. are they the same injector for 3800SC and 3800NA ?
conan469
Report this Post01-21-2014 01:36 PM Click Here to See the Profile for conan469Click Here to visit conan469's HomePageSend a Private Message to conan469Edit/Delete MessageReply w/QuoteDirect Link to This Post
maf code would be more like P0101 through P0107
