  door alignment is fun.........NOT
door alignment is fun.........NOT by jon m
Started on: 01-17-2014 11:54 AM
Replies: 5 (268 views)
Last post by: pdemondo on 01-18-2014 10:49 AM
jon m
Report this Post01-17-2014 11:54 AM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am in the process of refitting the doors back on my 87gt after replacing the hinge pins and bushes and making some mods
and basically I am having a ***** of a time lining up the door - I have read an archive post from randye and explains very good theory to lining up the doors which I am taking on board.
here https://www.fiero.nl/forum/A...130314-2-119449.html
my main question is can I get to the hinges which are bolted on to the car side by just removing the inner wheel well ? - without removing the fender
the bottom hinge hasn't got a roller bearing in yet - as I have rodneys repair kit to hand for when the door has been aligned so that wont get in the way of the bolt that's in plus the other bolt in the bottom hinge is accessible from inside the footwell
all opinions welcomed.
jon
Ducati Jones
Report this Post01-17-2014 12:44 PM Click Here to See the Profile for Ducati JonesSend a Private Message to Ducati JonesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep you can get to the bolts thru the fender liner. I just removed enough of the screws to where I could get my hand in there. I didn't have to remove the whole liner. When I bought my car the passanger door hung down and was hard to close. I thought the bushings were shot but once I started taking everything apart I realized that one of the bolts were missing. I bought a whole set of used hinges with bolts and only use one bolt.
gtoformula
Report this Post01-17-2014 12:56 PM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did the same thing except I had taken off the outer door skin before remounting the door. Really not that difficult to do. Much easier to get at the hinge bolts too.
jon m
Report this Post01-18-2014 04:56 AM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
thank you- this will help me no end
jon
Total ratings: 202
Report this Post01-18-2014 10:01 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, that's what I would recommend doing too... removing the door panel and trying to fit the door that way.
In the future though, I recommend drilling pilot holes through the hinge and the outer door frame on the car. I did this with a standard bit size (that matches a nail perfectly, and I was able to align them without any effort at all. The interesting thing for me was that after I removed the hinges and replaced the pins... I re-installed the door using the nail through the hole to align, and the door aligned more perfectly than I can ever remember it being. This happened of course because I kept hte original door alignment, and I replaced the pins / bushings. Not totally helpful now, I know... but in the future (or maybe for the next door). To fix up the hole afterwards (not real necessary), you can just put a little bit of black RTV sealant in it.
pdemondo
Report this Post01-18-2014 10:49 AM Click Here to See the Profile for pdemondoSend a Private Message to pdemondoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Method I use: no measuring or marking required. very quick and easy
remove or loosen up fender so you can get to hinge mounting holes.
put door in place and loosely put in a bolt on each hinge
completely shut door
tighten up all hinge bolts.
re-attach fender
