  Swapping Transmissions for a manual.
Swapping Transmissions for a manual. by zzzhuh
Started on: 01-15-2014 01:28 AM
Replies: 1 (125 views)
Last post by: mcguiver3 on 01-15-2014 06:53 AM
zzzhuh
Report this Post01-15-2014 01:28 AM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since the last post I did was very helpful and I realized how intelligent you guys are about the fiero I figured I would ask another 'newbie' question.
I have a 4 speed V6 1986 FieroGT and found someone on Craigslist that selling a 5 speed Getrag from an 88' for rather cheap. I heard the getrag is from muncie and i've read a lot of good things about them.
My question's:
Is there a thread here that explain this swap?
And does it cost a pretty dime or is it an exact bolt on,
also what parts will I need for this to work smoothly?
Anything regarding this is greatly appreciated.
Thanks guys!
The wetter the better
[This message has been edited by zzzhuh (edited 01-15-2014).]
mcguiver3
Report this Post01-15-2014 06:53 AM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
It will bolt up to the engine.
You will need, clutch and slave, trany mounts, shift cables and shifter.
Change axle seals. the reverse light switch is in the transmission on the 5 spd. I think your 4 spd is located at the shifter (not sure about that).
Been a while since I did one, could be a few other things to review.
I believe there are a few threads on this here do the search.
