  What could be wrong with my stock 87 fiero gt 2.8 v6?
What could be wrong with my stock 87 fiero gt 2.8 v6? by FieroGT-987
Started on: 01-15-2014 01:03 AM
Replies: 4 (188 views)
Last post by: FieroGT-987 on 01-15-2014 10:34 AM
FieroGT-987
Report this Post01-15-2014 01:03 AM Click Here to See the Profile for FieroGT-987Send a Private Message to FieroGT-987Edit/Delete MessageReply w/QuoteDirect Link to This Post
My 86 gt all stock Has new spark plugs, wires, ignition coil, had oil changed, I can gun it to the floor and it wont squeel the tires a bit. It isnt slow but it is not as quick as it should be.. Any ideas? I know this is VERY broad.. But I would appreciate any ideas. Thanks God Bless
mcguiver3
Report this Post01-15-2014 06:56 AM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Plugged cat?
Any codes?
Air filter new?
Full throttle plate through on the TB?
Could be a number of things, do you have a scanner to check things out?
Fiero84Freak
Report this Post01-15-2014 07:17 AM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you sure? ... The 2.8L V6 is kind of a dog. It's rated at around 140-ish HP, but you're more realistically putting out at the very least 20 HP less than that, then top off age of the engine which diminishes HP figures. I can gun my GT with the 5 speed and it rarely chirp tires.
But yes you may want to check for intake and exhaust flow and make sure everything is working properly.
Although I think ultimately you're going to find out this is why so many people do drivetrain swaps.
Report this Post01-15-2014 08:32 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Lots of variables. Tire size, tread, oil weight, you could check your engine compression, etc.
FieroGT-987
Report this Post01-15-2014 10:34 AM Click Here to See the Profile for FieroGT-987Send a Private Message to FieroGT-987Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks everyone. I forgot to mention. It has no cats, new air filter. So airflow is good. Maybe i could try to clean the throttle body or somwthing or just leave it as it is. I am selling it and am trying to get my gt back to perfect running condition but this might be just as close as it gets haha.
